OEM coil resistance
Old Oct 19, 2011 | 07:53 PM
OEM coil resistance
Does anyone know the resistance of the stock VTR coil and high tension lead combo?
Thanks in advance!
Old Oct 19, 2011 | 09:11 PM
It's not specified in the manual, but I would guess between 6k and 8k ohms.
I might add that if it's over 30k ohms, there is definitely a problem. No ignition high tension lead should ever have over 30k ohms resistance, regardless of length. Typical secondary coil winding resistance is usually somewhere around 1000 to 1500 ohms, plus or minus.
Old Oct 29, 2011 | 05:09 PM
mikstr, just for your info:
I had my tank off today to replace the air filter, and I checked the rear coil resistance while I was under there. From the primary connector behind the tank to the spark plug terminal is 18.24k ohms.
Old Oct 29, 2011 | 05:50 PM
thanks
nate3676
Jun 8, 2012 05:33 PM
Montana
Jul 28, 2011 01:11 PM
finepooch
Aug 14, 2008 04:32 AM
divingindaytona
Apr 30, 2005 05:06 AM
Markrs1980
Apr 21, 2005 08:58 AM
