LED Resistance
Old Apr 27, 2005 | 05:35 PM
divingindaytona's Avatar
Remember stock is BAD!
LED Resistance
Yesterday I installed new turn signals in the front. They are LED's.
Does anyone know what resistance I need to make the turn signals flash at a normal speed?!
Also, where do I need to put this in the circuit to make it work properly?
Old Apr 27, 2005 | 06:38 PM
skinnyj's Avatar
skinnyj
measure the resistance of your stock bulb, probably around 3 ohms. I'd put it close to where the turn signal harness plugs in. make sure you get the signal wire and not the running lights. use one resistor for each side. let me know how it turns out
Old Apr 27, 2005 | 08:17 PM
VTRDarren's Avatar
VTRDarren
or just splice in an oem size bulb and tuck it in the front bodywork....
Old Apr 28, 2005 | 05:49 AM
L8RGYZ's Avatar
Darren,
Sounds interesting. Explain in a little more detail &/or attach a picture.
Thx,
Steve
Old Apr 28, 2005 | 09:30 AM
VTRDarren's Avatar
VTRDarren
The text below if from another discussion list I'm on. The guy had put LED's in his passenger peg brackets and was looking to slow down the blink. Another lister initially made the suggestion I posted earlier. See below:
"99zx6r wrote:Thnx, made em myself. Just have to get some resistors to slow the flash down.
Rather than resistors just wire some bulbs in a Parallel circuit, and put them up in the tail section. Much more robust then standard carbon resistors."
I haven't done this mod. and can't offer any first hand experience. Makes sense though.. just splice in a regular tail or turn signal bulb. Might be a little weird at night if there's occasionally a blinking light under your seat or within your front bodywork :-) Might be cleaner to just splice in a resistor, but that would require a trip to the store ....
Old Apr 30, 2005 | 05:06 AM
VTRumble's Avatar
Re: LED Resistance
You could also get a thermal flasher from just about any local parts store. It only costs a few $, and is fairly simple to hook up. I did it on mine 2 years ago and have no problems. I'll try to get out and get a pic later, just kind of tough with a 1 year old and a 3 week old in the house.
Doug O.
nate3676
Jun 8, 2012 05:33 PM
mikstr
Oct 29, 2011 05:50 PM
Montana
Jul 28, 2011 01:11 PM
Anto
Sep 12, 2009 11:47 AM
Anto
May 5, 2009 05:20 PM
