Spark Plug Indexing
Old Aug 14, 2011 | 01:19 PM
johndoeafro's Avatar
johndoeafro is on a distinguished road
Question Spark Plug Indexing
Does anybody know what indexing works best for the sooperchikkin? I'm thinking it should have the electrode facing directly in between the intake vlaves (shroud to the exhaust side) but have read that that is not always the case, dependent, of course, on the engine. Does it seem to decrease any slight occurrence of missfire? I don't expect any noticeable gains, I only want to burn fuel as efficiently as possible.
Old Aug 14, 2011 | 02:16 PM
autoteach's Avatar
just spin those plugs in there
Old Aug 14, 2011 | 03:50 PM
jay956's Avatar
first ive heard of this
Old Aug 14, 2011 | 04:08 PM
autoteach's Avatar
ngk's website says that indexing spark plugs is possibly good for less than 1%, and it would be difficult to gauge on a dyno, would require extensive testing, and quite possibly is a waste of time (I added the last as an inference from what I could tell from their description).
Old Aug 14, 2011 | 05:02 PM
Stevebis1's Avatar
Waste of time???
People here loose sleep over Rotella vs Amsoil, stick coils verses OEM, which oil filter to use, Nitrogen in the tires...
John - I have no clue what orientation is best, but if you discover anything that you think works best please report on it
Old Aug 14, 2011 | 05:47 PM
NooB's Avatar
I loves me twins
I really don't think indexing applies to overhead cam motors. I think it's more of a pushrod motor thing, since the plug is usually angled off to the side of the head.
Old Aug 14, 2011 | 06:08 PM
autoteach's Avatar
Yeah, tell us which orientation is best...
And as for nitrogen, I fill mine with 78% nitrogen whenever I can.
Old Aug 14, 2011 | 06:42 PM
Gregw's Avatar
I always smile when I see that.
Old Aug 14, 2011 | 09:30 PM
Teachers......
in the business of dashing the hopes and dreams of America's young men. [applicable emoticon denoting that I'm not stabbing too seriously at autoteach]
I've done more reading and have concluded that spark plug indexing falls somewhere between magic and obsessive nitpicking ninety percent of the time. Some engines absolutely require indexing whether it is for proper ignition or for piston clearance (i.e. Honda Element for the former and various small engines for the latter). I have been playing with it in a small fleet of chainsaws and have NOT been able to perceive any difference at this time. I still wonder though, over the long run, if there would be anything detectable within the exhaust or exhaust valves. I'm not sure of precisely how the PAIR system is controlled, but would I detect less ignition in my pipes, if indeed, indexing was effective?
Old Aug 14, 2011 | 10:17 PM
A big +1 on 78% nitrogen!... although I think the optimal amount may be closer to 79%.
And just make sure those plugs are torqued properly.
Old Aug 15, 2011 | 06:28 AM
nekkid's Avatar
No one can tell...
Don't you know Orientations are inscrutable?
Old Oct 29, 2011 | 06:37 PM
1971allchaos's Avatar
[QUOTE=VTRsurfer;311589]A big +1 on 78% nitrogen!... although I think the optimal amount may be closer to 79%.
I use 100% helium in my tires, it increases Miles Per Gallon on the 1000cc motorcycle- Which seems to have been in the "Waste of Time" category...
Waste of time???
seattlesucks
Jul 26, 2007 06:48 PM
Chitownson
May 28, 2007 11:08 AM
ATLSHawk98
Dec 21, 2006 09:32 AM
motojoe
Oct 3, 2005 04:19 PM
Quebecer
Jun 29, 2005 08:18 PM
