Highway Resistance
Old Jun 8, 2012 | 02:02 PM
nate3676's Avatar
nate3676 is on a distinguished road
Highway Resistance
I've got a weird situation going on with my 03 superhawk.
When on the highway the bike will not be smooth at all when cruising. It feels resisted than it feels ok, its a herky back and forth.
When you go wide open there are no issues.
When you accelerate there are no issues, you only feel it when you are cruising between 60-100ish.
I think it has something to do with the wind because if you trail closely behind a car the bike run smooth.
The windier and colder it is the less smooth the bike runs.
Any ideas, its really annoying
Thanks, Nate
Old Jun 8, 2012 | 02:06 PM
What kind of shape is your chain in and how is it adjusted?
Old Jun 8, 2012 | 03:04 PM
HRCA#1's Avatar
+1 Classic tight spot in chain.
Old Jun 8, 2012 | 03:40 PM
nate3676's Avatar
how do i fix?
Old Jun 8, 2012 | 04:01 PM
RWhisen's Avatar
Former Superchicken Owner
Raise your rear wheel and rotate it to feel if any of the links on the chain are bound up. Each one should move individually.
How to fix it? Get a new chain.
blamecanada's Avatar
blamecanada is on a distinguished road
I have the same issue and have been chasing carb settings around because of it...I'll check my chain too!
Old Jun 8, 2012 | 05:33 PM
HRCA#1's Avatar
It's marginally harder than that. The chain may apear to be OK you have to slowly rotate the wheel and check variations of the chain slack to find where it might be tightening, unless it's really screwed up and the it should be obvious.
Bad chains=bad sprockets=R&R both.
mikstr
Oct 29, 2011 05:50 PM
Montana
Jul 28, 2011 01:11 PM
Thumper
Nov 16, 2008 05:49 PM
bob4pres
Jul 25, 2008 10:38 PM
divingindaytona
Apr 30, 2005 05:06 AM
