no power will not start
Old Jul 12, 2009 | 02:31 PM
vtr98bob's Avatar
vtr98bob is on a distinguished road
When I turn the ignition on I have no power. The main 30a fuse is ok, has continuity. All the other fuses are ok. No clicking from the starter relay. The battery has 13.35 volts. Will not start, no horn, no lights. I have continuity at the battery ground and a secure positive connection at the battery. Do the ignition switches go on these bikes? Any thoughts or ideas would be appreciated.
Regards
Bob
Old Jul 12, 2009 | 02:38 PM
MOONSTER's Avatar
Can you check to see if you have voltage @ both in & out of the main fuse? If so next step would be to see if you have same voltage to ignition switch.
Old Jul 12, 2009 | 06:27 PM
vtr98bob's Avatar
Thanks for the suggestion. There was no voltage out when ignition is on. I also tested the starter relay switch as stated in the 1998 Honda vtr repair manual, chapter 18-10. The switch lacked continuity when I followed the test procedure so it appears to be the relay switch.
Bob
Old Jul 14, 2009 | 08:55 AM
Circuit_Burner's Avatar
guru of things sparky
Take a screw driver while the bikes in neutral, and short between the two main terminal bolts. If the starter spins, its the main circuit. (main fuse socket in solenoid)
mau
Jul 25, 2011 11:58 PM
Montana
Aug 7, 2010 07:12 PM
amhsraptor
Jul 12, 2010 06:55 PM
ghopki1
Jun 4, 2009 08:17 PM
jivtrky
May 17, 2007 12:49 AM
