Bike Cranks (No Start) Will Push Start Though
Old Aug 1, 2010 | 08:04 AM
Montana's Avatar
Montana is on a distinguished road
Hello Everyone. My 2000 Superhawk will crank and crank but will not start. I try it with choke, without choke, stand up, stand down, neutral and in gear with clutch to rule out safety switches. i crank it to a point that the battery dies. It seems to be cranking fast like it always does. If I have someone push start me then it fires right up. I think the starter might be taking to much juice from the coils or the coils are getting weak. Any ideas will be appreciated. thanks. Anthony
Old Aug 1, 2010 | 08:16 AM
Start with the basics... You could have a weak battery/defective R/R meaning not enough charge on the battery to start, but enough to run...
When fully charged what voltage is the battery? Should be at a minimum be above 12.5V or else the battery is highly suspect... When running, what charge voltage at idle? And at 3000&5000 rpms?
Could also be the starter motor... All of theses are mote likely than coils...
Old Aug 1, 2010 | 01:03 PM
Montana's Avatar
After I trickle the battery for a few hours it reads around 12.4-12.6 range. It drops fast after cranking a couple times for a few seconds each. Probably down around 12 or so. I also did a few checks and the voltage from the convertor to the coils while cranking is 9.56 . The voltage from the ICM is a little over 11. I think both should be 12 at least to fire the coils. I'm thinking the convertor is bad or the battery lost amperage even though is shows decent voltage. I cleaned as many connectors as I could resaonably get to also.
Old Aug 1, 2010 | 02:31 PM
The odds are on the battery, not the converter... Try hooking up a known good battery and trying again... Any 12V battery works, car/lawnmower/whatever... A larger battery will not harm the bike in any way...
Old Aug 1, 2010 | 04:48 PM
Montana's Avatar
Thanks. Will try Battery from car.
Old Aug 1, 2010 | 05:56 PM
wyldryce's Avatar
I doubt that this is 100% of your issue, but have you set the TPS to it's proper value? It can certainly make starting more difficult if it's out of spec.
-R
Old Aug 2, 2010 | 11:31 AM
Montana's Avatar
It bump starts really easy. Not sure if it would be the TPS. I can check that though if all else fails.
Old Aug 2, 2010 | 11:35 AM
Montana's Avatar
Got the battery load tested and it checked out ok. 206 cca 12.6 volts.
Hooked up car battery and the same result. Just cranks. No fire. I ground the plug against the valve cover bolt and didn't see any spark from the plug. I am only getting 11 volts with the key on to the coils. Shouldn't it be the battery voltage of 12.6? When I engage the start button voltage to the coils (out of the convertor) drops to the 10 range or high 9 range.
Old Aug 2, 2010 | 11:50 AM
blicraft's Avatar
blicraft is on a distinguished road
Can you pull a plug and see if its firing when you hold the starter button?
Old Aug 2, 2010 | 11:57 AM
A load tester isn't really a good way of knowing that much about your battery... It's an easy test, not a good test...
But the car battery should have worked if all else is OK...
Old Aug 2, 2010 | 11:59 AM
Have you gone through the test in the service manual? Ie the test to confirm the ICM connector and such?
Old Aug 2, 2010 | 12:17 PM
If it was anything other than the battery you shouldn't be able to bump start it either.
Old Aug 7, 2010 | 07:12 PM
Montana's Avatar
THE POWER OF CONTACT CLEANER. So after being ready to sell the bike for parts I decide to pull apart every connector on the bike like I should have the first time. instead of just looking at them I sprayed them with electrical contact cleaner. Not sure what connector it was but the bike started of on the first crank. I was in the frame of mind that it had to be a failing part and not a small connector or wire. I would suggest that if you have an electrical problem that is hard to diagnose; dip the bike in contact cleaner the go from there. Thanks for all the help especially Tweety who helps a lot of people on this site with good advice.
mikenap
May 7, 2015 08:37 PM
stumplove
Jul 29, 2013 09:20 AM
j shizzy wizzy
Feb 5, 2009 09:32 AM
PUSHrod
Dec 17, 2008 03:38 PM
NOrrTH
Aug 11, 2005 09:57 AM
