need help with integrated tail light
Old Jul 13, 2012 | 06:04 PM
  #31
BeerHunter's Avatar
Slacker
Ummm, apparently the Proton Flashers have their own flash circuitry and do not need a signal relay.
Old Jul 13, 2012 | 06:44 PM
  #32
RWhisen's Avatar
Former Superchicken Owner
Different resistence values enable dissimilar flash rates. A incandescent bulb flashes slower than an LED.
Old Jul 13, 2012 | 07:07 PM
  #33
Zedicus's Avatar
Zedicus is on a distinguished road
that is measured in MS. MOST humans cant see the difference, if you can see the difference it will be SMALL.
my bet would be as stated above, some LED blinkers have an integrated flasher.
Old Jul 13, 2012 | 07:10 PM
  #34
RWhisen's Avatar
Actually, resistance is measured in ohms and the delay was quite noticeable.
Old Jul 13, 2012 | 08:33 PM
  #35
Zedicus's Avatar
delay is measured in miliseconds. if it was truly that noticeable there was something else in line causing an exponential gain.
argueing the fundamentals of theory based on electronics in this case is about as usefull as pissing on a forest fire, or a paper sack on the titanic.
want to start down the trouble tree piece by piece? otherwise if you guess enough times surely you will get it right eventually.
Old Jul 13, 2012 | 10:00 PM
  #36
Size:  12.8 KBName:  popcorn2.gif
Old Jul 14, 2012 | 05:15 AM
  #37
RWhisen's Avatar
I don't understand your analogy of "a paper sack on the Titanic". What does that mean?
Delay is measured in whatever unit of time is appropriate and CAN be measured in milliseconds. For instance, in my business of avionics, I regularly use a device called a TDR (Time Delay Reflectometer). Coupled with a pulse generator, it can measure delays in the order of a nanosecond to isolate faults in circuitry or wiring.
If you wish to settle this in your own mind, without getting into the electronic theory of all of it, purchase a set of Proton LED turn signals, a Clear Alternatives tail light and hook everything up correctly. Run your test then tell me the LED and bulb blink at the same rate. Then add an electronic flasher to the circuit to see what happens with it installed.
Otherwise, since you have no basis in fact or observation because you weren't at my house when I ran through all of this, you should not try and tell me what I observed.
Didn't you part out your Hawk in 2009? You must be working from memory......
Old Jul 14, 2012 | 07:27 AM
  #38
BeerHunter's Avatar
Slacker
I have seen the effects of using straight LED signal lights when used in conjunction with standard incandescent bulbs. The LED uses much less current and comes on and goes off instantly, whereas the incandescent kind of ramps up when coming on. There can appear to be a delay between the 2 depending on the load placed on the flasher and quality of ground connections at the lights (have seen as much as 1/4 second), but the actual flash RATE is always the same (LED = 60 flash per minute - Incandescent = 60 flash per minute).
I have also seen these 2 different types of lights flash on and off with no discernible difference when the flasher (signal relay) IS loaded as designed and all power wiring and grounds are good.
The Protons seem to be different from a straight LED and can actually flash at a different rate from the other lights in the circuit if the relay is not loaded properly.
There was a discussion over on 600rr.net about this 3 years ago.
anyone elses protons flashing incorrectly?
Old Jul 17, 2012 | 11:11 AM
  #39
Zedicus's Avatar
seems like you read about every other line that i typed. somwhere someone got confused about something, good luck with your issue.
Old Jul 17, 2012 | 03:20 PM
  #40
RWhisen's Avatar
My bike doesn't have an issue, sorry for your confusion......
Old Jul 17, 2012 | 06:57 PM
  #41
aja's Avatar
aja
SuperMike
Aug 8, 2014 07:46 AM
Bearshawk
Aug 7, 2014 05:46 AM
Northman69
May 11, 2013 02:15 PM
Hawk2445
Jun 24, 2009 06:54 AM
seaton001
Mar 19, 2007 05:46 AM
