This is my Rectifier...
Old Oct 26, 2017 | 04:02 PM
Kelevra's Avatar
As I'm looking to change it, (if need be), am I looking at the OEM one, or an aftermarket one?
I see them on Ebay for $18-. What is the difference between those ebay ones, and the MosFet ones for around $100-?
I'm sure most of you replaced yours years ago, but this would really help, Thanks!
JD
Old Oct 26, 2017 | 04:26 PM
Now is the time to do the MOSFET swap.
Just fyi, compare this to what you have already found.
https://www.ebay.com/itm/2003-Yamaha...lVgx09&vxp=mtr
Old Oct 26, 2017 | 04:28 PM
All the info you need is here...
https://www.superhawkforum.com/forum...why-how-25117/
And here:
https://www.superhawkforum.com/forum...er-swap-14380/
Old Oct 26, 2017 | 05:49 PM
Kelevra's Avatar
Thank you. I've seen that thread, but my ADD kicks in and I get bored. Is there a Cliff's notes version? hahaha
So would you say mine in the foto is the original one?
Old Oct 27, 2017 | 07:40 AM
IIRC that is a stock R/R that was used on late model SH. It will also let you down, maybe not as soon. The R/R is one of couple of important up-grades/fixes that are imperative that they be dealt with. Not worth cheeping out on.
Old Oct 27, 2017 | 11:39 AM
Kelevra's Avatar
Thanks much. Not one to cheap out in general. Is there a simple plug n play unit that many are using? I really don't want to have to spice wires and get all crazy with it, haha.
Old Oct 27, 2017 | 05:44 PM
Not sure, maybe someone else www chime in, but I don't think that there is what would be a real upgrade to to stock that uses the stock connector. Eastern Beaver, Cycle Terminal are two online retailers that have all the wires needed to swap in the common mosfet R/R. All plug and play.
Check out the sticky about R/Rs
Old Oct 27, 2017 | 08:31 PM
You're either going to stay w/ the unreliable crap or you're going to get all crazy (no splicing, just cutting off old plug and adding new terminals). Your decision.
Old Oct 27, 2017 | 11:18 PM
Wicky's Avatar
what have you done to your "bike" today - Page 720 - VTR1000.ORG
Old Oct 28, 2017 | 10:15 AM
Kelevra's Avatar
You're the man, Wicky. Thanks a ton. Just soldered n wrapped a handful of wires for my new integrated tail light, so this looks no biggie. Which one did you go with?
Old Oct 28, 2017 | 10:19 AM
Kelevra's Avatar
Good info, thank you hombre.
Old Oct 28, 2017 | 11:26 AM
Wicky's Avatar
Click the link above the piccie - I crimped it to the connectors.
Old Oct 28, 2017 | 01:38 PM
The better solution is to use the correct connector, with a MOSFET RR.
Furukawa 250 QLW Series R&R Connectors are the correct ones and can be had from many sources.
I get them from a place called Cycle Terminal Furukawa QLW 250 most times unless im already ordering from Corsa Technic, LLC and then I order there https://www.corsa-technic.com/catego...ategory_id=101
Use the proper crimping tool and you have a life long job done using a modern sealed connector
Old Oct 28, 2017 | 10:54 PM
Kelevra's Avatar
Awesome. I'll check it out.
Old Oct 29, 2017 | 07:22 AM
Some reading fodder
The 1st MOSFET I installed on my SH
https://www.superhawkforum.com/forum...ing-r-r-24798/
and then later upgraded to the new SH version https://www.superhawkforum.com/forum...ies-r-r-34077/
Old Nov 8, 2017 | 01:51 PM
whatthefnck's Avatar
THE LANE CARVER
I guess it depends on how determined you are lol. I suffer from the same issue, and must remind myself of determination haha
Montana
Oct 9, 2012 05:40 PM
chickenstrip
May 30, 2007 11:48 AM
wardo996
Apr 26, 2007 08:43 AM
Blurr
Sep 14, 2006 08:58 PM
CNI Dawg
May 31, 2006 05:55 PM
