My Journey Into the Heart of The VTR
Old Mar 24, 2015 | 11:00 AM
  #121
thetophatflash's Avatar
Originally Posted by Big_Jim59
I rode it up the road, about 5 miles to get my state inspection so I can get my tags. I threw an old tag on it just to keep from being stooped.
First Impressions of the 2005 VTR1000 Honda Superhawk
• Fast!
• Handles like it is on rails
• Pulls HARD!
• Engine still sounds tappy
• Idle increased about 500rpm after ride
• It gets all the gears
• Engine sounds like a sewing machine (not what I expected.)
• Fast!
• I saw and indicated 90mph and wasn’t pushing it.
• Lots of torque right off idle
• It likes my dirt road better than my VFR
• The riding position kind of hurts my neck but I think I am not used to it.
The "sewing machine" sound is exactly the words I use to describe the engine tickover at idle.
Old Mar 24, 2015 | 05:10 PM
  #122
brothermike's Avatar
brothermike is on a distinguished road
Swap to the VFR bars, that should help the neck, it did for me anyway.
Old Mar 24, 2015 | 06:23 PM
  #123
Or Apex bars which i did after trying the VFR bars for a few years
Old Mar 24, 2015 | 06:49 PM
  #124
sjscicluna's Avatar
Great work mate
Old Mar 25, 2015 | 12:38 PM
  #125
RoadManiac's Avatar
European Member
You old guys and your risers and neck pain haha
uhum : my Gixxer has riser on it..... and i also get neck pain after a day hard work on the hawk (i am 25 )
Old Mar 25, 2015 | 03:18 PM
  #126
Big_Jim59's Avatar
I finally got my tag this afternoon. Then the power went out. This is not unusual at times here in rural Texas. I took that as a sign from God that I was to go ride and not sit behind a desk. I pulled the bike out and immediately discovered that the rear view mirrors were not tight. This is a result of my son and my fax-son-in-law “helping” me install the fairing. (It is much easier the second time around.) I got that taken care of and headed out. It was nice. The temperature was perfect but it was a little blustery. The biggest trouble was the POS roads we have around here. They delight in awarding road construction to the low bidder and it shows.
As with all shakedown rides it was not without incident. I noticed it stumbling at idle and it lacked a crisp throttle response. I had to keep the revs up, like an old Norton with Mag trouble. It turns out the one of my handy dandy auxiliary vacuum lines I installed, to aid in carb balance, lost its cap. I had one side at a loss for vacuum at low revs and I am pretty sure it was the side that drives the vacuum petcock. The ticking is still there but it is not so pronounced with my helmet on.
All in all it was a very fun ride. The bike itself and the riding position make you want to ride faster than you intend. I will probably change the oil and filter now.
Proof http://youtu.be/tJoTzZZXaO8
Old Mar 26, 2015 | 02:15 AM
  #127
Good to see your on it and going.
Now the next hurdle will be not to catch the deadly OCMD.
Many on here have it and at it's worst it can destroy relationships.
My friends are astounded at how much time I put into my VTR and how much I ride it.
Have a look at the carb setup thread by Hawk, it's a beauty.
Old Mar 26, 2015 | 09:48 AM
  #128
Congratulations on getting her out on your first real ride! It's wierd, hey? After I put mine together, I was very hesitant to do anything with it. But now after thousands of miles since the build, I flog the crap out of it and she is always ready for more. Very reliable bike.
As for the "sewing machine" sound, doing a bafflectomy really drowns that out.
Also, for seating position and your neck, back starting to hurt, like others said, you can get different clipons or even get superbike bars that come in all different heights and widths. You can also get a different seat or go DIY and make your own comfortable seat. You can also get aftermarket rearsets to move your foot position, but a lot of the aftermarket reasets move your feet up and back.
Seat DIY ~$30-$60 Aftermarket used ~$220 and up
Clipons VFR $50-$90 Aftermarket $180-$400+
Superbike bars with risers used ~$120 New ~$200-$275+
Rearsets $220 and up
Old Mar 28, 2015 | 03:48 PM
  #129
Big_Jim59's Avatar
I took it out today for a good run. I have a predetermined route for test rides and I did about 50 mile running between 65 and 80. The bike was running good but It was acting like the carbs were out of balance at low RPMs. I went back to the house and set the carb balance again. it was better. I rode up to Randolf and then took it up 121 to Trenton. I was keeping up with traffic and noticed I needed some gas. (I hate to fill the tank when I might have to take it off later.) I hit the exit and just as I slowed I heard a little tingling rattle and then it quit. I could get it started but only on the back cylinder. I had the wife and my strong son come and pick me and the bike up in the truck. A compression test shows no compression on the front cylinder. My timing shows to be spot on. Bear in mind I did not strip the heads but just installed them thinking them fine.
After a break I went back to work and I am pretty sure I have found the source of the annoying ticking sound and possibly the source of the engine meltdown. I pulled the cams and the intake cam popped up. It seems that the valve spring keeper, or what was left of it, finally let go. I was only able to find a small piece of it. I think I got lucky as the valve didn't drop into the cylinder. We shall see what the piston looks like with the head off.
Old Mar 28, 2015 | 07:03 PM
  #130
Oh no!
Old Mar 28, 2015 | 07:24 PM
  #131
I think you have one of the two retainers that hold the valve and spring together.
Old Mar 28, 2015 | 07:59 PM
  #132
Big_Jim59's Avatar
It is hard to tell from the picture but that keeper is worn away and damaged.
Old Mar 29, 2015 | 02:18 AM
  #133
Lucky mate!
Just replace the affected parts and enjoy the bike.
As we say her in Oz"Bloody Lucky Mate!"
Let us know how you go.
Old Mar 29, 2015 | 04:48 AM
  #134
meaning the valve is as well...likely the keeper too. Send both heads to a reputable shop, Fast Heads, Engine Dynamics, or another and have them gone though.
Old Mar 29, 2015 | 08:04 AM
  #135
Big_Jim59's Avatar
I would like to but I am running out of funds for this adventure. I got the head off this morning and yes the valve was bent. There was no visible damage to the piston crown and I hope the rod was not bent. I did find two more pieces of valve spring keeper and they all look round and worn like this had been going on for some time. I am going to put it back together and hope for the best. If It fails again I will probably look at used engines.
Old Mar 29, 2015 | 10:07 AM
  #136
There has been quite a few guys that have had the stock CCT failure where the valves were bent with very little to no damage to the piston let alone the connecting rod. They just put on a good head and kept on riding.
Really sucks that you have to tear into her again.
Old Mar 29, 2015 | 12:52 PM
  #137
Big_Jim59's Avatar
You know, I does suck but I now know what that tapping noise was and I would have been forever worried about it. Now I can fix it and I'll lay money that the engine is nice and quite after this.
Old Apr 5, 2015 | 03:12 PM
  #138
Big_Jim59's Avatar
The head is back together with its new intake valve, keepers and springs. I installed new seals, lapped all the valves checking the seats. They all look fantastic. I checked the valve clearance with the head on the bench. I screwed up the clearances when I disassembled the head. All but one of the valves needs shimming. I have a few shims but, as always, they are the wrong sizes. I will go by the dealership next week and get the shims I need.
There needs to be a shim clearing house/library. Mail in your old shims and get shims of the correct thickness back for a fee.
Old Apr 9, 2015 | 06:47 PM
  #139
Big_Jim59's Avatar
The head's back on and the timing is spot on. I must check the valve clearances and keepers on the rear cylinder and then I will button it up.
Old Apr 10, 2015 | 12:17 AM
  #140
sjscicluna's Avatar
Excellent work mate
Old Apr 10, 2015 | 03:03 AM
  #141
Great news mate.
Maybe post a video of how it sounds compared to before!
Hope you enjoy the ride!
Old Apr 10, 2015 | 06:18 AM
  #142
thedeatons's Avatar
The good news is that your engine should be good for a while.
It's nice to know you've had your hands on everything, and know it's ok
James
Old Apr 10, 2015 | 07:01 AM
  #143
Big_Jim59's Avatar
Because I only found three pieces of broken valve collets when I disassembled the head, I did pull the pan and check for bits but found nothing of interest in there.
Old Apr 10, 2015 | 08:50 AM
  #144
CrankenFine's Avatar
For having owned your 'Hawk such a short period of time, I would venture to say few of us are so intimately acquainted with the engines on these bikes!
Hope it runs long and smooth for you from here on out. I have really enjoyed reading all your exploits with this bike.
Old Apr 10, 2015 | 09:58 AM
  #145
Big_Jim59's Avatar
It is really funny. I remember my first experience with this bike and the trepidation in just removing the tank and air box. Now I rip through those with the easy of long practice.
It's a pretty simple modifation but I split the vacuum line to the petcock and added a junction. This way there is one less hose I have to grapple with. It also allows me to easily hook up my hand vacuum pump so that I can pull a vacuum on the petcock assuring a good supply of gas in the carbs for start up. I have already added a T junction in the line so that the carbs can be synced with ease.
Old Apr 11, 2015 | 07:12 PM
  #146
Big_Jim59's Avatar
It is all back together again. I checked as much of it as I could and it does sound better. I was able to sync the carbs this time so that proves I have a stable vacuum on both cylinders. A sticking valve really screws up the vacuum. I made a video show it running.
http://youtu.be/0aw8oCzA6nY
I did ride it down the road (no helmet) so I could hear what it sounds like under load. It is a lot nicer than before. If you can hear it in the video the clutch side makes a "luck, luck, luck" sound but it definitely comes from the clutch side.
Old Apr 11, 2015 | 07:30 PM
  #147
Still sounds a little funny to me, you think clutch? Here's a short vid I made of mine a while back. whir? I've never noticed that sound in any of the Hawks I've heard in person.
Old Apr 11, 2015 | 07:59 PM
  #148
I agree with Wolverine. It still sounds...off. Like it has a clunking. Very similar to what I was dealing with, but mine was more of a solid "ticking" noise, which was a clutch that destroyed itself (click here).
It honestly sounds like a large part, like a wrist pin, or a connecting rod.
Old Apr 11, 2015 | 08:03 PM
  #149
thedeatons's Avatar
Jim's sounds about like mine... Oh and did i mention i love the color?
The "whir" is crazy. Definitely doesn't sound normal. If you told me your mccts were too tight i wouldn't be surprised... No offense intended, just sounds odd
James
Old Apr 11, 2015 | 08:04 PM
  #150
Maybe it's just me.
James, it sounded like that before the mcct's.
