My Journey Into the Heart of The VTR
Old Apr 11, 2015 | 08:20 PM
  #151
Big_Jim59's Avatar
I can honestly say that the big end was checked (I pulled the pan) and the small end was checked during assembly. It really does sound like the noise is coming from the clutch side.
Is it possible that I installed the anti-rattle gear wrong? I used the stethoscope and the bulk of the noise is coming from that area. When I insatlled the gear I though it had some tension. When I tried to install it with a full tooth to compress the springs I was unable to do it and thought that this would put too much tension on the gear and springs.
Old Apr 11, 2015 | 08:58 PM
  #152
You can always remove all doubt and eliminate the sub gear (anti rattle gear). However, that would require draining the coolant and a new side cover gasket.
Old Apr 11, 2015 | 09:02 PM
  #153
Maybe it's just me.
James, it sounded like that before the mcct's.
That sounds just like the "whir" every Superhawk has, like a gear drive, but just a lot louder. Sounds cool, I think. I wouldn't worry about it.
Old Apr 12, 2015 | 05:48 AM
  #154
Maico88's Avatar
Maico88 is on a distinguished road
That noise in your Hawk is just like the noise that I have been worrying about in mine. I am going to ride mine a while before I pull the cover . I still have to get the tools (puller) so it will be a while. The noise in mine seems to vary. Sometimes loud and sometimes not loud.
Old Apr 12, 2015 | 07:04 AM
  #155
Big_Jim59's Avatar
I think I'll ride and try not to worry about the noise. When it needs it's first oil change, I'll pull the fairing, drain the coolant and get in there and remove the anti-rattle gear.As luck would have it, I have a new clutch cover gasket on the shelf.
Storms today so no ride.
Old Apr 12, 2015 | 07:43 AM
  #156
Big_Jim59's Avatar
It is the loudest and most noticeable at idle. It does not get louder nor does it change under load or with the clutch pulled. I am going to call it finished for a while, ride it some and think about it.
Old Apr 12, 2015 | 09:08 AM
  #157
What puller do you think you need for the engine side cover? Or am I reading that wrong?
Old Apr 12, 2015 | 09:30 AM
  #158
Maico88's Avatar
I thought that I would have to pull the clutch. Am I mistaken?
Old Apr 12, 2015 | 09:35 AM
  #159
Big_Jim59's Avatar
You can pull the clutch plates without a puller. You only really need a puller for the flywheel. To pull the clutch basket you will need a tool to hold the clutch or an impact wrench.
Old Apr 12, 2015 | 09:52 AM
  #160
Thumbs up
Straight cut primaries. Definitely not worried, but mine is the loudest I've ever heard. I made the vid because another member on here was concerned it was a problem. I get the good looks from people wondering if there's a blower or something.
I said maybe it's just me referring to his clunking which I haven't heard before.
Old Apr 12, 2015 | 10:19 AM
  #161
Big_Jim59's Avatar
I was listening to it this morning and it reminds me of a Honda FT500 Ascot I used to own. It had a chain driven, over head cam, and a primary drive exactly like the VTR. It made clunking sounds from the bottom end just like this.
Old Apr 12, 2015 | 02:00 PM
  #162
That sounds like mine!
I have no ant rattle gear, 4 degree advancer, manual CCT's and a few other bits.
Been like that for years and like you I was worried with the noise.
I chased the noise for ages and in the end decided to ride it and see what happened.
So far nothing.
Do you have a 4 degree advancer?
A lot of folks all over the world report a noise like yours when an advancer is fitted.
Old Apr 12, 2015 | 03:05 PM
  #163
Big_Jim59's Avatar
I really can't say. Since I haven't owned the bike from new and since I just installed the advancer it came with then it is quite possible that this is the case. The bike does sport a Two Brothers exhaust, which was not a cheap mod and it has the jetting mods to match. Someone liked the bike enough to make some upgrades, why not the advancer?
Old Apr 12, 2015 | 03:42 PM
  #164
Did the advancer have a couple holes in it? If so, that would be stock. If it is solid, then it would most likely be a Factory Pro advancer. Some have a "4" or "2" stamped into one of the teeth. However, regarding the +2 degree Factory Pro advancer, I have never seen one, so this is just an assumption.
Old Apr 12, 2015 | 04:19 PM
  #165
Big_Jim59's Avatar
I do not remember it having any holes in it but my memory is shocking these days. I have pictures of just about everything except that!
Old Apr 12, 2015 | 04:32 PM
  #166
Don't mean to tax your memory further, but was it a yellowish, gold color?
Old Apr 12, 2015 | 08:12 PM
  #167
Big_Jim59's Avatar
No, I think it was a dull nickle finish.
Old Apr 13, 2015 | 02:33 AM
  #168
A theory that I came up with is that when I removed the anti rattle gear and put the new advancer in that the position the new advancer was in in relation to the trigger was different by the thickness of the removed anti rattle gear.
Fortunately I still have the anti rattle gear and if I ever have the need to, or the inclination to remove the clutch cover I will fit a washer behind the advancer that is the same thickness as the anti rattle gear and see if that stops the noise in my motor.
I haven't been into that side of the engine for a couple of years so I hope that my thoughts make sense.
The main thing is that even though I have the noise, my bike goes like stink.
I guess that when things are changed from standard you have to expect the engine to sound different.
You obviously know your way around an engine, have the faith and ride it.
I am that used to the noises my VTR makes now that if it didn't make those now familiar sounds I would be worried.
Best thing is with loud pipes you can't hear them when you are riding anyway!
Go on, jump on it and give it a good flogging!
Old Apr 13, 2015 | 02:35 AM
  #169
Sorry, I will find my old advancer and post a pic when I get a chance.
It may help you.
Old Apr 13, 2015 | 05:30 AM
  #170
Maico88's Avatar
Thanks Big Jim
Old Apr 13, 2015 | 07:25 AM
  #171
Big_Jim59's Avatar
For me having faith in my work is the hard part. There are so many details and as you ride or listen to the engine you think "did I miss anything?"
The noise it makes does not get louder as the RPMs increase and it's not the sound of the exhaust drowning it out. It just makes that clunky sound, the loudest at idle. Strange.
It is raining and I have the job so riding will have to wait.
Old Apr 20, 2015 | 02:55 PM
  #172
Big_Jim59's Avatar
I STILL haven't had a chance to ride it. The problem with my left foot has made shifting impossable. I got out yesterday with the shop sponsored group ride. We did about 200 miles round trip. I was not able to ride my own bike but I borrowed a NC700X DCT that the shop had taken in on trade. The DCT let my foot relax the whole way and was possibly therapeutic with a bit of pulsating massage from the twin motor. I like the bike just fine but it could use more power. It was a nice trip but I am just desperate to get on the VTR.
Old Apr 25, 2015 | 05:09 PM
  #173
Big_Jim59's Avatar
Today the sun was shining and temps were in the high 80s. It was too good a day not to ride so I first pulled the VFR out and made a run into town. That done I managed to get the VTR liberated. Bear in mind this is no small task as the path from the shop roll up door to my drive is over my yard which is still standing in water. I decided to ride a set route and I made sure the ramp and the tie downs were in the truck. I rode the 6 miles from Leonard to Trenton and back a couple of times. On my way out of Leonard I got pulled over by the local cop and I was given a warning for 60 in a 45. This bike draws cops like flies to honey. The clutch side is still a bit clunky but I am going to call it finished until something else breaks. It runs strong and pulls hard. It is really hard to ride this bike slow although, after the warning, I was creeping along like a Harley dude.
Old Apr 26, 2015 | 03:02 AM
  #174
Great to see your riding it.
Mine has had some terrible noises since I modded it a couple of years ago.
I have learnt to live with them as you only hear them at idle.
To add to that I have a noisy clutch as well.
Still when I compare it to the noises the V4 Tuono makes I can live with it.
Ride and enjoy.
Old May 27, 2015 | 08:31 AM
  #175
Big_Jim59's Avatar
I used my GoPro and an external mic to try and get a better audio file of the VTR running. It sounds a bit muffled but I think it captures the essences of the sound. Please give it a listen and let me know what you think. There is just a hint of rattle in the sound. I put a 1/4 turn on the rear CCT but that's all I am willing to do. Too tight is way worse than too loose. I have been riding it, as much as the monsoons we have been having will allow, and the sound doesn't bother me as much. Maybe I am getting used to it. The bike is quite powerful and very fun to ride. I guess I am having trouble putting my trust in it.
https://youtu.be/mRbaskaQvEM
Old May 27, 2015 | 09:46 AM
  #176
killer5280's Avatar
Mine makes that sound.
Old May 27, 2015 | 01:19 PM
  #177
thetophatflash's Avatar
Sounds pretty much like mine, 'cept it ain't yeller. Manual CCT's?
Old May 27, 2015 | 01:56 PM
  #178
Big_Jim59's Avatar
That's good to hear. Yes manual CCTs. I set them per the instructions and I know that are not too tight. I guess I'll just go ride.
By the way. I love yellow. My VFR is yellow and I think if make me easier to see in traffic. When I take the VTR out I have to be careful. It is silver/gray and I think it blends in. It's like I have a cloaking device. (Except where the cops are concerned.)
Old May 27, 2015 | 02:11 PM
  #179
Big Jim,
Mine sounds like that too!
After a couple of years you get used to it.
I just did the shims in my valves and rechecked my cam chain tension .
I am yet to start my bike. I had to shim 1 inlet and one exhaust on the front head and am wondering if that contributes to the noises that I hear with my bike.
I guess I will find out.
Mine has the clutch rattle but the knocking noise seems to be coming from the primary drive area on mine, but more towards the front.
Old May 27, 2015 | 02:51 PM
  #180
Big_Jim59's Avatar
Big Jim,
Yes, it has a little rattle, as the engine decelerates, like a little piston rattle but not bad. I can't say that mine is a clutch noise because it make the same sound whether it is engaged or not. Most of the noise is centered around the clutch side. I guess it make sense with all the gear and chain movement in there. I can see why they put the anti-rattle gear in there to try and sooth the noisy beast. It's hard to sell a bike that sounds like it has bottom end troubles.
I am heartened to hear that everyone's SH sounds like mine. I felt I was getting a bit paranoid.
