Modify Master Cylinder for brake lines?
Old May 26, 2016 | 12:26 PM
CrankenFine's Avatar
I did not see this particular front brake issue discussed anywhere in the Technical Discussion forum previously so here goes.
I recently added HEL stainless brake lines up front & thought I was pretty careful about mounting and routing them. But the other day I noticed one of the lines gets flexed pretty hard at full left steering lock due to the gauge cluster being in the way.
To me it looks like the mounting boss sticking off the end of the master cylinder should be modified or removed for the kinds of hose ends on HEL brake lines so they can angle down more sharply for clearance.
Anybody run into this issue before or solve it another way?
Old May 26, 2016 | 01:10 PM
I cut mine off because I did not like the angle that the brake line was held at. I have never warmed up to the dual lines out of the master. At some point I will eliminate the second line and split the single line somewhere down stream.
Old May 28, 2016 | 05:30 PM
Cadbury64's Avatar
VTR virgin
I Dremeled the pegs off the master cylinder so I had more freedom in line placement and master cylinder orientation.
Old May 28, 2016 | 07:06 PM
I did the same thing.
Old May 28, 2016 | 11:01 PM
Modify, That's what i do.. the "peg" is an idiot proof alignment "tool" so the OEM line will be placed in the correct, indexed position, as you're no longer using the OEM line, no need for the peg.
Old May 29, 2016 | 04:57 AM
Add me to the list. I too removed enough material to route where I wanted.
Old Jun 2, 2016 | 03:39 PM
Thanks all for the replies.
Remving the extension "seemed" obvious, but thought you guys know more than me so what's the harm in asking for some consensus.
Old Jun 2, 2016 | 04:42 PM
stainless-f-brake-lines
speigler-brake-line-upgrade-question-
Duck007
Dec 14, 2006 05:42 PM
supertwinSH
Nov 30, 2006 07:54 AM
Sighter
Sep 8, 2005 07:17 AM
roadrun_fr
Jul 12, 2005 10:44 AM
