May have clutch issues?
Old Apr 15, 2010 | 05:27 PM
dshakes's Avatar
dshakes is on a distinguished road
So i have this odd sond that has developed when i let out the clutch and accelerate. In first and second its noticable but not much after that. Not sure if its cause its too loud at that point or just not there. Now to try and describe it. I dont even know. A hollow aluminum sound? Like the sound of sitting idle with the clutch out but different. I am clueless how to describe it so if you guys want to start throwing ideas out go for it.
Old Apr 15, 2010 | 05:45 PM
residentg's Avatar
does it feel like the clutch is slipping? it could be so many things...
Old Apr 15, 2010 | 06:02 PM
drew_c14's Avatar
It's probably your rear caliper. Had the same thing happen to me once.
Old Apr 15, 2010 | 07:56 PM
Do you have an advancer on your bike? It could be detonation (pinging) if your timing is overadvanced.
Try short shifting into 2nd at about 2000 rpm, then open it up. If it sounds like marbles bouncing off your pistons, it's detonation. Which could also be caused by excessive carbon deposits in the combustion chambers and/or low octane fuel.
Old Apr 15, 2010 | 09:06 PM
dshakes's Avatar
I havent had a chance to really feel it out yet. I noticed close to my house and once i pulled it into the garage i have not had it back out. I did try shifting different with no change in the outcome. VTRsurfer, i dont have an advancer. Its only under load in the first couple gears. I dont know....
Old Apr 15, 2010 | 10:25 PM
Over advanced timing is only one possible cause of detonation. Detonation only occurs under load, and is most noticeable when load is applied (full throttle) at low rpm. But of course you don't want to do that in 1st. That's why I said try short shifting, and nailing it in 2nd at low rpm. Or just slow down to below 2000rpm in 2nd then nail it.
Did you fill up with gas just before it started doing this? I once bought gas from a station, and my truck detonated like crazy going up a hill. I ran a couple of tanks from another station with no problem, then tried the first one again, and again got bad detonation. I never bought from that station again.
So try filling up with premium, or add some octane boost. If it still makes the noise, it's probably not detonation. Good luck.
Old Apr 16, 2010 | 01:46 AM
residentg's Avatar
Is the noise present when you are still, moving, or both?
Old Apr 16, 2010 | 03:45 AM
dshakes's Avatar
At idle with the clutch in or out its fine. Once settled at speed its fine. Its noticible when letting out the clutch in first and after shifting to second. i will try and diagnose a lttle better today. Its work time now though
Old Apr 16, 2010 | 04:18 AM
nath981's Avatar
are you using motorcycle specific oil. Could be affecting clutch?
Old Apr 16, 2010 | 04:23 AM
nath981's Avatar
kink in your chain from a bound link? can you feel or just hear it?
Old Apr 16, 2010 | 01:51 PM
dshakes's Avatar
I used supertech oil which guys have recomended and i used it before. Could be i suppose its having an effect. I cant really feel it . Its just audible at this point.
Old Apr 16, 2010 | 03:29 PM
nath981's Avatar
you may wanna put a stethoscope on it.
Old Apr 16, 2010 | 03:49 PM
This what it sounds like to me or maybe the chain is just adjusted too tight.
Have you had the rear wheel off lately? Have you checked the chain alignment & tension?
Old Apr 17, 2010 | 09:36 AM
dshakes's Avatar
Got some free time today so i think i will check the chain over and give her a good listen.
Shane702
Apr 29, 2013 07:15 PM
rafbo
Jul 16, 2011 10:24 AM
frankym
Apr 7, 2011 05:04 PM
andy9743
Mar 30, 2008 12:33 PM
VTRBandit
Feb 16, 2007 04:09 PM
