Lithium back up battery arrived
Old Oct 27, 2014 | 10:43 AM
So I got my battery from the Netherlands (off ebay). It was $45 to my door. Looks awesome. I plan to mount it under the seat as a never get stuck with a dead battery plan.
It is super compact & light & I plan to get another one for my racebikes. Figure I can swap it to whichever bike I am racing and save a ton of weight.
Now I just have to figure out how often & how to charge it. It seems to have 13.7 volts as it sits.
Old Oct 27, 2014 | 08:04 PM
98VTRrider's Avatar
Wow, $45 shipped from Netherlands is impressive.
For occasional charging could you just make a jumper to run it parallel with the main battery? Then it would charge on your ride, just have to remember to unplug it when you get to work.
Old Oct 27, 2014 | 08:42 PM
Just ordered one for myself ... will have a look at the cells when it gets here. Planning on using it as a primary battery on the 990 SM
Old Oct 28, 2014 | 02:42 PM
macdee's Avatar
macdee is on a distinguished road
hi joe would you have a link for this battery
thanks
Old Oct 28, 2014 | 03:50 PM
Here is the link bruthaman 8 Cell A123 18650 Motorcycle Start Battery 13 2V2 2AH 12V New A123 Battery Pack | eBay
Just ordered a second one for racing.
Old Oct 28, 2014 | 04:10 PM
Crap that's cheap. I'd do what 98VTRrider suggested- wire it in every couple of months to charge it. I can vouch that if they are healthy cells they will sit for a long time and hold charge.
Old Oct 30, 2014 | 03:16 PM
macdee's Avatar
thanks joe
just might have to get one of those
Old Oct 30, 2014 | 07:18 PM
sjscicluna's Avatar
Wire it in parallel with a relay and an override switch so when the bike is running its charging and when you turn the bike off it disconnects the connection the override switch will allow jump starts.
Old Oct 30, 2014 | 10:01 PM
sj, I was actually thinking of putting a battery disconnect switch on the backup battery for now. This way can turn it on when I need it.
The question is, if the Li battery is only used in emergencies, how often do I really need to charge it? I was under the belief that they will sit a long time without maintinence.
Old Oct 31, 2014 | 09:21 AM
Yeah I think every other month or so would be on the safe side. I have a pack that's 1 year old still holding a charge... and I didn't treat that pack well at all either. But it was also stored in a cool dry place. It will be interesting to see how they do romping through pothole land in sub-freezing temps... but I'm a huge fan of the LiFePO technology and would trust it myself.
Old Nov 7, 2014 | 11:43 AM
RoadManiac's Avatar
European Member
Lithium battery are horrible in cold weather
because when cold it just wil not conduct as warm so starting up will take up to 4 try's and looking quite stupid when it doesnt start then you scare the **** out of those who are watching(or not) with a huge backfire
i take it out everynight..... made easy by R/C gold connectors and velcrostrip
Old Nov 7, 2014 | 06:44 PM
No need to go through that, just turn on the power and headlight for a min or so.. same thing Helo pilots do in cold weather .. pull some juice for a min and then start.
Old Nov 7, 2014 | 06:45 PM
Uggg, still waiting on mine, going on 4 weeks now....
Old Nov 8, 2014 | 06:00 AM
RoadManiac's Avatar
European Member
thanks for the tip
Old Nov 11, 2014 | 02:04 PM
carkifelek's Avatar
carkifelek is on a distinguished road
joe, $45 for a lithium battery, that too from Netherlands, I must say I’m surprised. I read your query about how to charge it, please do not connect it in parallel with the main battery. You can use only one battery at a time. Since your current battery and this one will have a voltage difference, they won’t be able to provide the required current, (up to 30A) at the time when engine is being started. You’ll have to charge the battery outside to be safe.
circuit board fabrication
mikstr
Oct 14, 2014 05:56 AM
scottiemann
Mar 28, 2014 02:43 PM
Birdoprey
Mar 26, 2007 06:42 PM
joshn569
Mar 9, 2007 04:22 PM
icebud
Jul 26, 2005 06:27 AM
