A knocking clanking noise!?
Old Mar 12, 2011 | 09:35 PM
jbrobinson08's Avatar
jbrobinson08 is on a distinguished road
So I have just purchaced a 99 real cheap, needed some tlc but seems to have turned out good. I drove it for a few days and seemed great but today I started it and reved the motor to about 4000 rpms and when it came back down at idle it would clank/knock sometimes loud sometimes not so loud and would do it for a sec or two and stop. It didnt do this evertime i reved it but was pretty regular about it. Maybe cct? what else would do this?
Old Mar 13, 2011 | 06:20 AM
RWhisen's Avatar
Former Superchicken Owner
I would pull the top covers so I could get to the cams and check the slack in thetiming chains just to alleviate any concern. Does it have manual or OEM CCTs?
Old Mar 13, 2011 | 06:33 AM
FL02SupaHawk996's Avatar
Fastest Color
+1 could be chain slap from cam chains if the CCTs arent doing their job...many replace the OEM CCTs with APR manual CCTs.
Also could just be a loud clutch. Put it in neutral and pull in the clutch lever to see if sound goes away...
Old Mar 13, 2011 | 07:39 AM
jay956's Avatar
carb fart?
Old Mar 13, 2011 | 10:02 AM
to my knowlede they are the cct are oem. it was in neutral when i did it but i will pull the clutch to see if it changes anything. Im not familiar with bikes if I would have heard this in a car i would be like F but i have read alot of the stuff on here seems like the stuff on this motor require it to be just right............... would a carb fart be that loud?
Old Mar 13, 2011 | 10:59 AM
Ok so I just fired up the bike and it instantly made the noise and did not stop when i pulled in the clutch. I turned it off and started it agian and it didnt make any noise, stopped it started agian and made the noise this entire time it didnt run smooth at all
Old Mar 13, 2011 | 01:51 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
Only one way to find out what is going on - download the workshop manual from the knowledge base section of the forum, check the valve timing and clearances, and strip/clean the carbs while you're in there (replace the pilot jets - it's easier than trying to clean them).
Old Mar 13, 2011 | 01:58 PM
Sounds like a CCT going out. You might not want to run it until you find out what the problem really is.
Old Mar 13, 2011 | 03:19 PM
RWhisen's Avatar
+1
Old Mar 13, 2011 | 04:50 PM
So with some tinkering I the rear cylinder is missing would this cause the noise as well? I still need to check the front and even if the chain seems fine i am still going to replace the tensioners. the cru's seem the same but cheaper should i jsut be safe and go with apes? and thanx for all the input
Old Mar 13, 2011 | 06:08 PM
RWhisen's Avatar
I would go with manual CCTs anyway and yes a dead cylinder may cause some noises like that. Pull up the tank and check your plumbing coming off the petcock.
Old Mar 27, 2011 | 08:09 AM
20_rc51_00's Avatar
does it sound like this? YouTube - VTR1000f Superhawk idle problem
Old Mar 27, 2011 | 10:56 AM
geekonamotorcycle's Avatar
I was about to say can you record it?
Old Sep 2, 2022 | 07:55 AM
HarryDunn's Avatar
Mr. Squid
HarryDunn is on a distinguished road
+1
Old Sep 3, 2022 | 03:23 AM
CWC's Avatar
CWC
CWC is on a distinguished road
Possibly the front carb slide clacking. Filling a lift hole fixes this.
Old Sep 3, 2022 | 07:35 AM
Guys, this thread is from 2011. These guys have long since moved on.
Maico88
May 17, 2015 06:42 PM
foosfan
Mar 28, 2014 07:40 PM
996vtwin
Sep 13, 2011 01:31 PM
ericrosendall
Nov 25, 2009 07:30 AM
Reason
Jan 28, 2009 08:44 AM
