Ignition Switch Bolts Question
Old Apr 24, 2008 | 08:34 AM
FL02SupaHawk996's Avatar
Fastest Color
Question Ignition Switch Bolts Question
I searched but couldn't find an answer
For those who have changed out top triples or ignition switches please help
I've run into two 8mm bolts that hold the switch to the top triple that are one way, so I can't get them out
Will they have to be drilled or is there another way?
Thanks,
Rick C.
Old Apr 24, 2008 | 09:22 AM
Drill them and use safety bolts (variuos odd looking heads...)...
Old Apr 24, 2008 | 09:36 AM
Fastest Color
Thanks Tweety, figured I'd have to do that...ain't nuthin' but a thang
RC
Old Apr 24, 2008 | 04:01 PM
Whaddya mean by "one way"?
Old Apr 24, 2008 | 06:04 PM
Fastest Color
Greg, it's like they are designed like bathroom stall bolts! You know the ones that you can screw in, but can't remove
I figure it must be some type of theft deterrent...not sure, but seems like you can't get them out unless you drill them...
I'm surprised nobody's run it to it before...RC
Old Apr 24, 2008 | 07:07 PM
Can you take a pic or do up a quick drawing of what the head looks like. I might have some ideas for you.
FWIW, my 98 has regular bolts.
Old Apr 24, 2008 | 07:40 PM
Mine was like that...
They come with a breakaway bolt head... basicly the head is shaped like a hourglass with a bolthead on the upper part and once tightened the "waist" breaks leaving a smooth cone shaped head with a coarse flat tip of the break... No way of unscrewing them unless you drill them to get a holding point...
Old Apr 24, 2008 | 08:00 PM
superbling's Avatar
Put a good (not rounded off slightly) allen wrench or socket on them and give them several good hits with a hammer as Honda used mega-thread lock on them and that should be enought to break them loose when you try again.
Old Apr 24, 2008 | 09:06 PM
happytrack44's Avatar
WERA #44
I am occasionally required to remove such bolts professionally to repair ignitions or fit keys.
1-drill hole down center of head and drive a tight allan wrench or ez-out into the hole and back out
2-use stoutest pin punch that will fit, make a dent on the outermost edge you can get to of the head, then angle the punch in the dent and tap counter clockwise with a hammer. Do not gall metal over to the housing as you will tend to peen it together
3-Slot the head with a dremel cut-off wheel and use a screwdriver.
I like the punch the best
Old Apr 25, 2008 | 05:26 AM
Fastest Color
Thanks everybody!
I'll get pics up ASAP of before and after. If there's anything left to take a pic of after I blast those bolts out...
Old Apr 25, 2008 | 07:33 PM
Fastest Color
here's a couple of before pics, sorry about their quality...you can see the two brass colored bolt heads that attach the switch to the top triple.
Attached Thumbnails Ignition Switch Bolts Question-ignition-bolts-vtr-top-triple.jpg
Old Apr 25, 2008 | 07:34 PM
Fastest Color
Here's a close up, but it's fuzzy
Attached Thumbnails Ignition Switch Bolts Question-ignition-bolt-close-up.jpg
Fastest Color
Tomorrow I plan to set up the drill press and smoke those suckers!
Old Apr 26, 2008 | 04:29 PM
Fastest Color
Got those little suckers out today, but it was no small task!
Set up the drill press and blew through 3 bits! These suckers aren't made of brass they are Kryptonite!
Finally, I decided not to destroy any more bits and used a hacksaw to cut little groves in the bolt heads so I could get at them with a vice, hammer and screw driver!
Nothing that a couple of beers and some old fashion getter done engineering wont fix
Most importantly the top triple and switch both made it through the operation unscaved!
Old May 1, 2008 | 11:23 AM
Fastest Color
Here's some more pics and hope this helps folks in the future...this is a pic of the 3 spent drill bits and the ignition bolts after I took a hacksaw to them!
Attached Thumbnails Ignition Switch Bolts Question-ignition-bolts-after-top-triple.jpg
wtacoma
Jun 9, 2013 11:02 AM
inderocker
Apr 26, 2010 06:44 PM
fundgh
Jan 6, 2010 03:26 PM
TexasWino
Apr 14, 2008 12:54 PM
Hawkrider
Mar 5, 2008 05:33 PM
