How can I tell if I have a jet kit?
Old Mar 26, 2007 | 10:02 AM
Cleveland's Avatar
Post Whore Junior
I bought my bike used last spring. I am the third owner. The guy I bought it from saiad he got it for a guy that had a new bike every couple months or so, and usually did alot of work on them. It had Erion slip ons, now cut down.. How would I know if it had a jet kit installed? The guy I bought it from didnt have the slightest about the bike. He just bought it and rode it.. lol.. 300 miles in 4 years.
I have access to a dyno. (buddy owns a bike shop) I dont want to ask him and seem like a rube.. Like to know how I can do it myself.
Thanks.
Cleve-
Old Mar 26, 2007 | 10:23 AM
The easiest way to find out is to pull one of the needles out. If it has notches and a C-clip then it's aftermarket.
Old Mar 26, 2007 | 10:42 AM
Cleveland's Avatar
Post Whore Junior
Kind of nervous about working on the carbs. I am mechanically incline, though not knowledgable. I was hoping for an answer more like "dyno it, and if the HP is xx-xxx then it probably has a jet kit, if its xx-xx then probably not"
That would easy my curiousity for now.. then when I got ambitous I could dig into the carbs...
Old Mar 26, 2007 | 11:02 AM
cliby's Avatar
if it runs well, it won't matter either way. Just enjoy it till you have reason to get into the carbs. If its not running strongly throughout the low and midrange then maybe look further into it.
You could check the aircleaner as maintenance to see if that is stock - and then of course its only a short way further to the carbs - in fact you could remove the rear carb top probably with the airbox on and get a look at the needle as greg suggested.
Old Mar 26, 2007 | 11:18 AM
superbling's Avatar
You can access the rear cylinder needle without pulling the carbs. Also, if the black plastic tube has a hole drilled in it, you'll know it's a dyno-jet kit.
Be REAL careful putting it back in to not damage the needle tip and/or rip/bind the diaphragm membrane as compressing the coil spring under the cap is a tad tricky.
Old Mar 26, 2007 | 08:50 PM
gboezio's Avatar
Check the carb top screws for screwdriver damage on the unscrew side.
Old Mar 27, 2007 | 05:02 AM
Cleveland's Avatar
Post Whore Junior
Yeah.. this is good, I hoped there to be some things to look for as evidence traces...
thanks guys.
Old Mar 27, 2007 | 06:45 AM
cliby's Avatar
HaHa. perhaps the best way of all to tell if the carbs have been opened. Does anyone know why the manufacturers persist with those awful screws?
Old Mar 27, 2007 | 07:01 PM
JamieDaugherty's Avatar
Actually, I prefer the phillips screws over the socket heads. The torque is so light on those fasteners that it doesn't matter. I just find screwdrivers to be faster than an allen wrench. When you tweak a bunch this savings adds up!
As for not wanting to look like noob, just ask to have the bike dyno'd and play dumb. They should run an exhaust analyzer on it and will identify any problems with the jetting. Even with a jet kit installed it could still be off (and probably is). You are just checking it out in the condition you bought it, don't be embarrassed if it's not perfect. In fact, you can turn that around to your advantage by stating "I thought it was off." Ha!
awg13
Jul 26, 2010 09:54 PM
dsevans
Dec 24, 2008 01:22 PM
reaper
Oct 3, 2007 01:26 PM
MelliFobian
Dec 26, 2006 04:01 PM
NOrrTH
Mar 23, 2006 11:44 AM
