fuel tanks???
Old Sep 22, 2014 | 12:05 AM
dhmetalworks's Avatar
dhmetalworks is on a distinguished road
fuel tanks???
anyone know what the difference is between like a 98 and 03 fuel tanks? i have a 2003 with a hashed tank. everything i can see its just a difference in fuel capacity? will a earlier model tank work on an 03?
Old Sep 22, 2014 | 07:45 AM
Jack Flash's Avatar
Well take off, eh.
Fuel capacity is the same. Only in Europe was the tank enlarged beyond '01.
As for the internals, there are some differences on the inside, but will not necessarily affect function. You will have to make a very subtle mod to the fuel indicator lever since '01 to '05 have the fuel guage.
The float at the end of the lever needs to be bent from 90° to about 60° in order to clear one of the internal tubings from earlier model gas tanks. If you fail to do this, every time you fill up, your guage will only show that your half full. This tube on the Inside will prevent the float from rising all the way up to the top of the tank.
Other then swapping fuel guage indicator, and, bending with your hands the lever (if you chose to do this, it's not necessary) then it's a direct plug'n'play.
Old Sep 22, 2014 | 09:05 AM
thanks Jack!!
Old Sep 22, 2014 | 11:42 AM
NZSpokes's Avatar
We got bigger tanks to.
theosagekid
May 2, 2014 10:40 PM
cm526
Apr 25, 2011 11:43 AM
wshski
Jan 19, 2011 04:16 PM
yruyur
Apr 7, 2009 12:04 AM
streetfighter996
Dec 3, 2007 11:52 AM
