vfr 750 fuel tanks
Old Jan 18, 2011 | 11:31 AM
wshski's Avatar
wshski is on a distinguished road
vfr 750 fuel tanks
Since most the posts refer to VFR 800 tanks, anyone try a '95 to '97 750 tank. Thinking is, it is carb related so maybe you don't have to mess with redoing the FI fuel valve/pump stuff. But then maybe you still have to??
Old Jan 18, 2011 | 12:31 PM
Well... Considering the 750 have bodypanels covering the lower part of the tank and the shape is considerably more boxy, I doubt it will fit the frame as nicely as the 800...
My guess is, it would look butt ugly... But it might work...
For me though, I'd rather fix the hole for the pump on the underside than mess with the exterior though, less work, and less chance of messing it up...
Old Jan 19, 2011 | 12:36 AM
Stephan's Avatar
In Czech there is a guy who reworked VTR fuel tank from 16 to 24, it´s little more handy, but way to go
Old Jan 19, 2011 | 06:01 AM
r80gsman's Avatar
r80gsman is on a distinguished road
i looked at the bottom of a 750vfr tank and it looks much harder to do than that of a 800.. i bought an 800 to do the mod. and have not figured how i am going to get it to fit. i am thinking, lowering the the airbox lid in the rear by 10mm. which i think will allow it to fit and not hinder the air supply in the box
Old Jan 19, 2011 | 02:59 PM
nath981's Avatar
why not put an auxiliary tank under the seat if you need an another gallon? better weight distribution and less hassle? just a suggestion.
Old Jan 19, 2011 | 04:16 PM
kai ju's Avatar
I did look at the 750 tank before I went with the 800 tank.
A lot more work to make the 750 tank fit. Even if you consider making the block off plate for the fuel pump opening.
dhmetalworks
Sep 22, 2014 11:42 AM
theosagekid
May 2, 2014 10:40 PM
yruyur
Apr 7, 2009 12:04 AM
NOrrTH
Feb 21, 2009 01:59 PM
VTwin996Rider
Nov 2, 2006 04:41 PM
