Fluids question ?
Old Sep 13, 2010 | 06:58 PM
lylesvegas's Avatar
lylesvegas is on a distinguished road
Fluids question ?
Hey guys, I just picked up my hawk a few days ago. I changed the oil but was wondering with 8500 miles on the clock, and not sure of the routine maintenance intervals should I go ahead and change all the other fluids like brake, coolant, and any other you may suggest. Thanks for the advice........
Old Sep 13, 2010 | 07:03 PM
Brake fluid and coolant should be changed every 2 years. So If you don't know the history, it would be a good idea to do it.
And of course, when changing the brake fluid, the clutch is included as well.
Old Sep 14, 2010 | 01:03 AM
Stumpy's Avatar
+1 Dont forget the wetter
http://www.redlineoil.com/Products.aspx?pcid=10
Old Sep 15, 2010 | 05:30 AM
lylesvegas's Avatar
Any particular brands of brake fluid and coolant that are better for these machines ?
Old Sep 15, 2010 | 05:44 AM
Follow the spec.. DOT4 spec brake fluid and silicate free coolant... Brand is pretty irrellevant, but others might have other opinions... (No, higher spec isn't better...)
Old Sep 15, 2010 | 08:46 AM
I am actually running a mix of DOT4 and DOT5.1 in mine since that is what I had at the time I needed to bleed it and they are compatible.
Just don't mistake DOT5 for DOT5.1.. DOT5 is not compatible with anything else.
Just get clean stuff in there without adding any air pockets and you will be good.
Old Sep 19, 2010 | 12:30 PM
justinity's Avatar
Über Member
Originally Posted by Stumpy
Is this stuff any good?
Berry34
Mar 23, 2014 08:50 AM
insulinboy
Jan 7, 2014 03:47 PM
memmakersorg
Dec 10, 2012 12:27 AM
Mattaua
Sep 17, 2010 12:34 PM
nath981
May 3, 2010 09:30 AM
