Exhaust leak?
Old May 21, 2007 | 12:09 PM
Blurr's Avatar
Blurr is on a distinguished road
Exhaust leak?
I noticed the other day my Jardine slip ons were hissing there is a little leak on the right side on the bottom clamp.........also I heard a ticking down the bottom of the bike there is a clamp missing down off the engine going onto the other part of the exhaust......Would exhaust leaks be bad for the bike ? Cause it to backfire? Is there any goo I could put around the pipes to make a better seal or ?
Old May 21, 2007 | 12:36 PM
trinc's Avatar
are you talking about where the slip on mounts to the stock header ?
here is a breakdown:
http://www.ronayers.com/fiche/200_03...0&parent=13160
notice there are seals. you can try & use a permatex gasket glue ( or whatever brand your store carries )
but i have found it works best for tight fitting joints. try new high guage clamps first.
tim
Old May 21, 2007 | 12:53 PM
Blurr's Avatar
Well the one clamp on the underside of the bike coming out the back cyl is loose and theres not even a bolt in there and then the clamp for the slip on where it meets the stock pipe is hissing and you can feel it coming out.
Old May 21, 2007 | 02:36 PM
Blurr's Avatar
Yeah I need to get a bolt to clamp the main exhaust out of the rear cyl.......but the other clamp down where the slip on mid pipe meets the stock pipe no matter what I do has a little leak and its wont go on any farther down the pipe and like it almost seems theres a little crack on the stock part....
anyone know if I could just take it to a muffler shop and have them clamp everything down or throw a little weld to fix things or should I mess around further or go to a bike shop?
Are the stock header pipes expensive?
Old May 21, 2007 | 05:34 PM
Blurr's Avatar
Well I got some uber gasket maker stuff copper goo put it on the pipe slid it on and everything let it set and yeah no more leak from what I could tell. Seems the jardine clamps just arent very good...
Still need to get a bolt on the back cyl and see what I can do there
Seems slip ons are sure a pain in the ***, I assume I full systems go on the same way?
Hmmm wonder if the Leo Vince are any better
Old May 22, 2007 | 07:39 AM
swordfish's Avatar
yes they are a pain in the ***. especially high-mounts. I went through the same struggle. eventually I had to resort to automobile exhaust clamps because the bike ones were just too flimsy. I used some high temp gasket sealant and tightened them as tight as I possibly could. now no leak. but damn it was a months long battle. I think I'm gonna take it to a welder at some point soon anyway and make them truly permanent. they are hindle titanuims so they will never need repacking anyway.
Just_Nick
Jun 24, 2010 08:52 PM
Vega (streetfighter)
Jun 10, 2009 09:52 AM
chevy
Mar 20, 2009 08:16 PM
Arctic Fire
Apr 11, 2007 08:28 AM
vtr_rider
Aug 12, 2004 07:41 PM
