Exhaust Header normal?
Old Jul 27, 2014 | 07:56 PM
CrankenFine's Avatar
Does this right side header outlet look unmodified?
I have read several times here that it's common to have the right side exhaust cold with less exhaust pass thru at idle, but my bike seems to flow freely from both sides and exhaust system is same temp both sides. Wondering if OP modified this to have less restriction.
Old Jul 27, 2014 | 09:07 PM
jscobey's Avatar
Left is main and right is overflow. Looks stock
Old Jul 28, 2014 | 02:17 AM
main and overflow...um ok that is a new one....
but to answer the OPs question that is a stock header
Old Jul 28, 2014 | 03:54 AM
Originally Posted by 8541Hawk
... that is a stock header
OK thanks for the visual confirmation. It is curious I feel equal exhaust pressure at idle from both mufflers but at least I know it's stock.
Old Jul 28, 2014 | 04:03 AM
Thanks for the visual confirmation.
Old Jul 28, 2014 | 01:51 PM
Are you going to modify it?
Old Jul 28, 2014 | 02:45 PM
jscobey's Avatar
Learned that from a very knowledgeable gent over the pond.
Originally Posted by lloydie
You need to repack it as the left is the main one and the right is the over flow
Old Jul 28, 2014 | 02:50 PM
No plans to change it.
Its just that my experience of how this system flows is different from what some report. I don't observe any difference in exhaust from one side to the other, so I figured I'd ask knowledgeable folks if my header really appears unmodified from stock.
Old Jul 28, 2014 | 07:52 PM
Learned that from a very knowledgeable gent over the pond. Whom you happen to be buddies with.
Well can you explain it then?
It makes no sense to me no matter who says it.
In fact I would say that it is dead wrong, though I would like to hear your reasons why one side is a "main" and the other an "overflow" before I take the time to write out once again what is really going on with the stock header.
jb
Apr 19, 2015 09:58 AM
Streaky
Sep 11, 2008 09:21 AM
Josh
May 22, 2008 08:04 PM
darylward
May 19, 2008 12:40 PM
MUHerdFan
Apr 16, 2007 03:32 PM
