Exhaust Header normal?
1 Attachment(s)
Does this right side header outlet look unmodified?
I have read several times here that it's common to have the right side exhaust cold with less exhaust pass thru at idle, but my bike seems to flow freely from both sides and exhaust system is same temp both sides. Wondering if OP modified this to have less restriction. |
Left is main and right is overflow. Looks stock
main and overflow...um ok that is a new one....
but to answer the OPs question that is a stock header |
Originally Posted by 8541Hawk
(Post 376489)
... that is a stock header
Originally Posted by jscobey
(Post 376487)
Are you going to modify it?
(Post 376489)
Originally Posted by lloydie
You need to repack it as the left is the main one and the right is the over flow
Originally Posted by kenmoore
(Post 376525)
Its just that my experience of how this system flows is different from what some report. I don't observe any difference in exhaust from one side to the other, so I figured I'd ask knowledgeable folks if my header really appears unmodified from stock. |
(Post 376526)
Learned that from a very knowledgeable gent over the pond. Whom you happen to be buddies with.
It makes no sense to me no matter who says it. In fact I would say that it is dead wrong, though I would like to hear your reasons why one side is a "main" and the other an "overflow" before I take the time to write out once again what is really going on with the stock header. |
