Emulsion tube mix up
Old Jul 8, 2012 | 08:59 AM
cbrcrx's Avatar
cbrcrx is on a distinguished road
Does anyone know how to tell which emulsion tube goes where? Also, I heard the needles are different, too. If that's true, anyone know how to tell which one goes where on those?
Old Jul 8, 2012 | 09:54 AM
Old Jul 8, 2012 | 10:19 AM
RWhisen's Avatar
Former Superchicken Owner
You should probably read this:
https://www.superhawkforum.com/forum...-set-up-24769/
Old Jul 8, 2012 | 03:09 PM
cbrcrx's Avatar
Thanks, I saw the carb set up post right after I posted this.
Old Jul 8, 2012 | 03:25 PM
Thumper's Avatar
I am aby-normal on this topic as i run the same emulsion tube in both front and rear with great success around surging. There was a topic on this years ago on another forum where some guys tested changing this. I would have to check my notes, but a seem to recall i have the rear style emulsion tube in front and rear carbs.
Old Jul 8, 2012 | 04:27 PM
Running a rear emulsion tube in the front is the Factory Pro way of dealing with the issue. Personally I prefer, and have seen, better results by using the HRC method of plugging a lift hole in the front slide.
Though that is just me.
kelowna1971
May 31, 2013 05:52 AM
spitfirerecords21
May 16, 2012 04:28 AM
captkirk
Nov 15, 2009 12:14 PM
finepooch
Apr 18, 2009 03:17 PM
Randman
Apr 20, 2006 09:28 PM
