Dirt in motor
Old Sep 16, 2007 | 03:26 AM
ride57's Avatar
ride57 is on a distinguished road
Dirt in motor
I took the covers and oil pan off today. dirt in the pan, a little in the covers. nothing really on the oil pickup screen. Will try to take oil pump off tomorrow.
Took about 45 min to get this bolt out. Gotta helicoil this one.
Also, gotta get the left exhaust mount bolts out of the frame.
I took the valve cover off of the back cylinder. Did not see any type of debris up there. Will take off the other one and look at it sometime. I want to see how the oil pump looks on the inside. I will also use the bore scope and see what the inside cylinder walls look like.
Old Sep 19, 2007 | 08:37 PM
ride57's Avatar
I got the oil pump out tonight. Absolutely no debris inside the pump. My picture-fu is weak tonight, but nothing in the pump is good news.
Old Sep 20, 2007 | 07:25 AM
Scumbag's Avatar
Scumbag is an unknown quantity at this point
GOOD TO HEAR!
so when do you suspect to be back on the road..errr...track
Old Sep 20, 2007 | 08:14 AM
gboezio's Avatar
don't worry the debris won't make it past the filter, so the most important parts are clean (bearings). Good luck and good work so far, keep it up
Old Sep 20, 2007 | 09:10 AM
RickB's Avatar
It certainly wouldn't hurt after you get it back together run it for a bit and change the oil/filter again to get out any remaining debris you don't see - much you would after the break in period or just rebuilt.
MAB
Sep 29, 2010 04:28 AM
Wheelerboy
Mar 26, 2010 06:59 PM
mikstr
Feb 26, 2010 08:04 PM
t-dogg
Oct 30, 2009 01:21 PM
dive2277
Oct 26, 2005 09:54 PM
