cuts out in the rain
Old Jun 14, 2007 | 12:49 AM
d.g's Avatar
d.g
d.g is on a distinguished road
riding in heavy rain the vtr started cutting out at any speed, it would stall .l would pull over hit the starter button it would start first time take off get a few miles down the road same thing cut out start it again.its the first time its happened in 3 years of owning the bike and have driven in heavy many times before .would appreciate if any one knows whats going on
Old Jun 14, 2007 | 02:42 AM
gboezio's Avatar
Check the side stand switch, pulse generator wires, check all the wires that gets wet.
Old Jun 14, 2007 | 06:15 AM
superbling's Avatar
Thread moved.
Check front spark plug wire, check tank vent tube has sucked in water.
Old Jun 16, 2007 | 07:04 PM
+1 on tank vent.
Old Jul 6, 2007 | 07:55 AM
westcoast's Avatar
westcoast is on a distinguished road
I found that the front tire would kick up enough water into the ignition switch and would make mine cut out. I went about sealing all the connectors in the front of the bike with some electrical grade RTV. After that I had no more problems.
Old Jul 6, 2007 | 07:56 AM
ali_squidz's Avatar
spark plug wire.
spray some water on it at night and see if it arcs in the dark
Old Jul 6, 2007 | 08:21 AM
Randman's Avatar
Moderate-whore
I saw my brother **** on a spark plub once, he walked funny for a few days...Wish I had a camera at that time...
Old Jul 6, 2007 | 08:32 AM
ali_squidz's Avatar
you mean spark pluG?
Old Jul 6, 2007 | 08:59 AM
L8RGYZ's Avatar
Now THAT would be some "shrinkage"!
Old Jul 6, 2007 | 10:28 AM
blokeontheend's Avatar
blokeontheend
I remember from years ago that a wet K&N filter causes prob's - just a thought.
Old Jan 9, 2008 | 07:53 PM
hondascott's Avatar
hondascott is on a distinguished road
rain stalls
My 98 is doing the same thing. Rear cylinder fails first then a mile or two the front goes out. Let it sit a few minutes and it starts on the front cylinder but the rear doesn't fire unless it sits even longer. I would think that the pulse generator, sidestand switch, or vent tube would kill everything. Any other thoughts? Scott
98 vtr1000, erion pipes, stage1 jet, intergrated tail light, corbin gunfighter, 3/4" handle bar risers, kevlar lines....
Old Jan 10, 2008 | 01:39 AM
Yeah it was your brother....um sure ok.....
1150NakedHawk
May 22, 2013 04:13 PM
Mosus
Apr 19, 2013 05:43 AM
ima98chickenhawk
Jul 3, 2010 02:54 PM
skokievtr
Jun 28, 2008 10:17 PM
Lilbitz909
Jun 6, 2007 10:02 PM
