Carb adjustments
Old Aug 2, 2017 | 08:57 AM
menace's Avatar
menace is on a distinguished road
Carb adjustments
So I know there is plenty of topic on this already but allot of the posts are not very clear on mods to carb setup. I have only a delkavic slip ons with out the DB killer and a 4° advancer. Everything seems ok but not perfect. I have a slight flat spot or something at 4000 rpms when holding constant speed. So I was going to set the bike with 48 pilots 2 turns out and shim the stock needles .030 and .040 like hawk suggested. What do you guys think?
Old Aug 2, 2017 | 10:41 AM
rktdoc's Avatar
rktdoc is on a distinguished road
With stock airbox and filter, probably won't need the shims, just the larger pilots, and 2 1/4-3 turns out on slow speed
Old Aug 2, 2017 | 11:03 AM
menace's Avatar
When you say on a slow speed what do you mean exactly. Thanks for your time
Originally Posted by rktdoc
Spoiler
Old Aug 2, 2017 | 07:54 PM
rktdoc is referring to the idle mixture/fuel screws. Not to be confused with slow jets, which would be your pilots.
Old Aug 10, 2017 | 09:13 AM
menace's Avatar
changed to the 48 pilots seems like a different bike. loving it
Old Aug 11, 2017 | 07:09 AM
menace's Avatar
ok so i have only ridden my hawk about 3 times since i put the 48 pilots in. i am having one issue. when i start it at a cold start it and pull the choke it runs at 2000rpms then after thirty seconds it starts to fall slowly and dies. i have my a/f mix screws at 2.5 turns out i assume that this is the problem. was thinking of turning them in about a half turn. what do you guys think?
Old Aug 17, 2017 | 01:45 PM
Fastguy59's Avatar
I didn't see him mention anything about a stock airbox and filter... did I miss something?
Old Aug 17, 2017 | 01:47 PM
Fastguy59's Avatar
Question, look down at your choke ****, is it staying pulled out, or is it self retracting?
storm_rider
Oct 4, 2009 11:07 AM
Vega (streetfighter)
Apr 10, 2009 03:24 AM
Jan 1, 2009 11:44 AM
EngineNoO9
Oct 12, 2006 06:50 PM
ClevelandSuperhawkRumble
Mar 12, 2005 10:23 PM
