Carb adjustments
So I know there is plenty of topic on this already but allot of the posts are not very clear on mods to carb setup. I have only a delkavic slip ons with out the DB killer and a 4° advancer. Everything seems ok but not perfect. I have a slight flat spot or something at 4000 rpms when holding constant speed. So I was going to set the bike with 48 pilots 2 turns out and shim the stock needles .030 and .040 like hawk suggested. What do you guys think?
Originally Posted by menace
(Post 403433)
When you say on a slow speed what do you mean exactly. Thanks for your time
Originally Posted by rktdoc
(Post 403435)
Spoiler
(Post 403436)
changed to the 48 pilots seems like a different bike. loving it
ok so i have only ridden my hawk about 3 times since i put the 48 pilots in. i am having one issue. when i start it at a cold start it and pull the choke it runs at 2000rpms then after thirty seconds it starts to fall slowly and dies. i have my a/f mix screws at 2.5 turns out i assume that this is the problem. was thinking of turning them in about a half turn. what do you guys think?
I didn't see him mention anything about a stock airbox and filter... did I miss something?
(Post 403435)
With stock airbox and filter, probably won't need the shims, just the larger pilots, and 2 1/4-3 turns out on slow speed
Question, look down at your choke knob, is it staying pulled out, or is it self retracting?
(Post 403537)
