Bolt is stuck
Old Apr 6, 2020 | 08:32 PM
Dahl's Avatar
Dahl is on a distinguished road
Bolt is stuck
Hey,
So my husband has a 98 superhawk and has been trying for over a month now to replace the rear tire. He can't get the bolt loose. He's not sure if its reverse threaded or not or if there's something he needs to do first. It is jacked up of course. He bought it used without a manual and the previous owner never had to change a tire on it. If I could get some advice on the best way to do this I would greatly appreciate it!
Old Apr 7, 2020 | 11:25 AM
CaryDG's Avatar
Are saying that the Nut won't break loose or the axle is stuck? If it's the nut, use a longer breaker bar. If the axle is stuck, remove the nut, use something to protect the threaded end i.e.; block of wood, Etc. and strike it with a hammer while trying to rotate the axle from the sprocket end.
When reassembling it put a thin coat of lithium grease on the axle before reinserting it. This will prevent future difficulties. Re torque to 69 lbs ft.
Enjoy
Old Apr 15, 2020 | 05:14 PM
I've wrestled with more than a few axles at the bike shop over the years. If it's just the nut, apply some heat (keyword some). Don't make it cherry red or anything. If it's the axle, have fun... A decent brass drift helps as does a friend. One twist and pull while one hammers and curses. When it's out, clean it up good on a wire wheel and coat with your choice of grease. I like white lithium for that.
Old Apr 22, 2020 | 02:32 PM
ACE VenTRa's Avatar
They are on there pretty tight. Normal thread...I use an impact when necessary. Sounds like a good time to buy a Milwaukee cordless.
AV
hawking
Sep 20, 2015 05:24 PM
thedeatons
Sep 17, 2015 07:49 PM
MILKMAN65
Nov 27, 2012 03:44 PM
floppyhat
Mar 27, 2009 08:38 PM
pickle.of.doom
Mar 19, 2006 03:57 PM
