Turning crankshaft rotation bolt while bike is in gear
Old Sep 20, 2015 | 01:30 PM
hawking's Avatar
hawking is on a distinguished road
I just replaced my CCTs and have been rotating my engine in the process. I started by using the rear wheel rotation method with the bike in 6th gear, and then switched to rotating the engine via the bolt on the crankshaft (behind the 10mm allen key cap). I left the bike in 6th gear after switching methods. Could the extra resistance cause the crankshaft bolt to loosen, or create any other problems? Everything seems fine, but I want to make sure I don't need to re-torque the rotation bolt or anything...
Old Sep 20, 2015 | 02:51 PM
Did the bolt break loose or otherwise rotate?
Old Sep 20, 2015 | 03:51 PM
hawking's Avatar
Nope, bolt didn't break loose or rotate. I'm probably just being paranoid...?
Old Sep 20, 2015 | 04:54 PM
Paranoid and using the bolt as intended.
Old Sep 20, 2015 | 05:24 PM
hawking's Avatar
Cool, thanks for bringing me back to sanity.
Apocalypse
Jun 14, 2015 09:47 AM
blue firestorm
Jul 16, 2009 05:44 PM
comedo
Feb 23, 2008 10:19 AM
Les
Dec 29, 2006 01:35 PM
W-O-T
Oct 7, 2005 06:03 PM
