Bike bogging at certain rmp in each gear.
Old Jul 3, 2016 | 06:29 PM
Apocalypse's Avatar
Night Rider
Apocalypse is on a distinguished road
Just running this by everyone before i tear apart my carbs to clean them and switch main jets out.
My hawk runs normally up to a certain rpm in each gear 1st 8000 2nd 7000 3 6500 4th 6000 and so on. after that it boggs down like if the engine is getting flooded with little blips of power after that rpm but it will not go more then 300 rpm above that.
Does this sound like a overly rich main jet to you guys or are there other problems you guys can think of?
I did do an engine swap and i had a friend try and work on the carbs with the old engine. I'm thinking that since the old engine wasn't running properly I may need to go back to the old jets and do some other adjustments.
Old Jul 3, 2016 | 07:22 PM
Cadbury64's Avatar
VTR virgin
You might be getting some fuel starvation caused by the vacuum petcock. Before launching into the carbs it would be worthwhile inspecting this component to see if it is doing the right thing. If you didn't know, the vacuum petcock shuts off the fuel when the engine is not running. It uses a vacuum signal from the rear inlet port to move a diaprgam which opens a valve and allows fuel to flow to the carbs. If the diaphragm gets damaged due to age it may not be opening fully and limiting fuel flow when there is high demand.
Old Jul 3, 2016 | 09:23 PM
Apocalypse's Avatar
Night Rider
I'll take a look at that before i tear into the carbs and order a rebuild kit if needed. Thanks for the reply always helps to have a second person to point out things you dont think about.
Old Jul 4, 2016 | 02:14 PM
Apocalypse's Avatar
Night Rider
well i took apart the petcock and checked it and everything is in good condition so im thinking that isnt the problem. ill be taking a closer look at the carbs after i make a sync tool.
Old Jul 4, 2016 | 09:06 PM
Just_Nick's Avatar
Who are you?
I would order a new one, regardless. It's a delicate rubber piece that will eventually fail, and it can cause you issues when it does. Furthermore, there may be a pinhole in it that you cannot see, and it's fairly inexpensive. Did you also make sure that the vacuum hose was attached to the correct place on the petcock?
You would need an absurdly massive main jet for it to get so flooded that the RPM won't increase, so I wouldn't rely on that being it, but I would make sure that your settings are correct. I would also make sure that you properly seated the carbs, as they can be a tad tricky and the front or rear may sometimes not fully seat. This will wreak havoc with how the bike runs. Make sure to clean everything out in the carbs, and make sure that you have smooth operation of the float needles and that they aren't binding/getting stuck. That can also cause issues.
You can also check your spark plugs, making sure they're fresh and fully seated. Same for the coils, ensure that they are properly seated and that they're tight at their mounting points with no corrosion.
Old Jul 5, 2016 | 06:58 PM
Apocalypse's Avatar
Night Rider
I did put it on the right way. but i tore into the front carb today and the needle was actually bent and it looks like the pilot jet was pretty dirty as well i can just barely see a pinhole of light through it so i ordered a dynojet kit today and ill be breaking into the other carb later today to see if there is anything else i need to buy and replace.
i also already ordered new plugs they should get here tomorrow so that will help a bit i hope. If im lucky i wont need to replace anything else. ill also take a look at the coils to see if they need any cleaning up.
thanks for the help and ideas.
Old Jul 6, 2016 | 07:56 AM
Hmmm.... Dynojet kit. I would read Hawk's carb sticky first. Might save you a lot of fooling around.
Old Jul 7, 2016 | 02:52 PM
Apocalypse's Avatar
Night Rider
I have and i looked a a lot of the other threads as well and the dynojets are the closest to the stock needles in shape profile and they are adjustable without shimming the needles with washers and im mostly just planning to use the needles and maybe use the jets since they do taper to help atomize the gas and help burn a bit cleaner. but we will see i dont plan on useing the springs or drilling the extra holes on the slides and i will do some testing and tuning based off his suggesting based off what it does from there.
Old Jul 9, 2016 | 08:11 AM
Apocalypse's Avatar
Night Rider
put in the needles and jets from the dynojet and its running a lot better now i just need to do a little tuning on the mixture screw and i need to clean and re-oil my filter to let a little more are through as its running a little lean without the filter and a little rich with it.
Wolverine
Jan 19, 2012 05:08 PM
mikebrittain7
Apr 4, 2010 10:14 AM
twstd99
Apr 9, 2008 09:08 PM
vasaq
Sep 5, 2007 06:59 PM
BigVal
Apr 24, 2006 11:27 AM
