Clutch Master cylinder, cant get in gear. please help
Old Aug 17, 2014 | 11:22 AM
I wanna go FAST!'s Avatar
I wanna go FAST! is on a distinguished road
I just replaced the Clutch Master Cylinder assembly and now I have no pressure in the clutch handle and it stalls when i try to put it in gear. When I hold the clutch while the bike is in 1st I cant roll it.
Please help
Old Aug 17, 2014 | 11:26 AM
Wicky's Avatar
Have you bled it?
Old Aug 17, 2014 | 11:34 AM
thetophatflash's Avatar
Originally Posted by Wicky
Have you bled it?
++++1
Old Jul 10, 2016 | 04:55 PM
Apocalypse's Avatar
Night Rider
Apocalypse is on a distinguished road
bleed
Have you bled it?
couldn't agree more and even if you did i would run fluid through the system again just to make sure.
Also on a side note you want to make sure that you open and close the bleed nipple properly when your putting fluid through the system.
Old Jul 10, 2016 | 05:02 PM
Try bleeding it twice after you think it's good Clutch bleeding can be finicky because you don't get the lever feel like you do with brakes. Watch the fluid coming out of the hose attached to the bleeder. Only let a somewhat small amount to come out each time and be very cautious to not let that small **** cup get empty. Keep at it and you'll get it.
NZSpokes
May 6, 2014 02:09 AM
six6nine9wpk
Aug 11, 2010 07:33 AM
Darrell400ex
Feb 17, 2008 06:42 PM
nineighthawk
Apr 26, 2007 10:04 PM
CNI Dawg
Mar 19, 2007 02:57 PM
