Battery is Dead: No tender. Car Jump start?
Old May 4, 2011 | 01:19 PM
FastRED's Avatar
FastRED is on a distinguished road
Hello,
More Hell than o right now. You see i rode my bike to the supermarket, while at work, then got back outside, and the battery was dead.
So now my bike is stuck there, any suggestions?
Old May 4, 2011 | 01:24 PM
If you can't bump start it, you can jump it from a car but make sure the car is NOT running the large alternator in a car can fry your electronics.
Old May 4, 2011 | 01:25 PM
You can jump it, just don't turn the car on- both are 12v systems. Or, if you're good, you can bump start it- just roll it forward in first gear and drop the clutch. I've never needed to bump start the Shawk, but have done it on other bikes (my shadow required this on a regular basis until I caved in and bought a battery).
Old May 4, 2011 | 01:26 PM
Hawk wins this time
Old May 4, 2011 | 01:31 PM
FastRED's Avatar
Haha, thanks. I tried to bump start it, unsuccessfuly, but while i was walking back to work, i was wondering if it would have been easier to bump it in 2nd.. Shouldve tried but it was too damn hot to do another 15mph sprint with my 400+ lb bike.
Old May 4, 2011 | 01:35 PM
To have any chance at all you need to be in 2nd or 3rd.
Old May 4, 2011 | 01:39 PM
FastRED's Avatar
There you go, thank you again for the tips, i dont like leaving my baby in a parking lot by herself..
Old May 4, 2011 | 02:45 PM
CrankenFine's Avatar
I was apparenly very lucky. I jump started mine the very first day I took possession.
Similar situation, took it off the UHaul trailer on a Supermarket lot across from Uhaul where the trailer needed to be returned. Was planning to ride about 6 blocks to home after dropping off the trailer. Turned the key, battery too weak to start. (It started fine the day before when I bought it)
I did jump it from my car battery not realizing the risk I was taking. But it all worked out fine, my bike started &my electrical system did not fry. But I honestly can't say for sure whether my car was running or not, I don't remember that.
"I'd rather be lucky than good.."
Old May 5, 2011 | 04:54 PM
fred's Avatar
Mid-level Member
fred
+1 on jumping from a car battery with the car engine OFF. you'll be amazed at how fast your starter turns. pull the cables off quick once it's started. bump-starting an SH... i wouldn't even consider it unless you have a hill pointing down.
Old May 5, 2011 | 05:20 PM
A big +1!
If you try to bump it in 1st, there's a good chance you'll end up going down, since you'll probably lock up the rear wheel...or wheelie for the first block if you give it too much throttle and it starts.
Years ago on previous bikes, when I lived in a condo without a garage, and therefore without a way to charge my battery, bump starting in 2nd while rolling down the hill was a regular experience.
I probably bumped my '86 Nighthawk S and my '83 BMW R100RS over 100 times during the 10 year period when I lived there. That was mostly during winter, if I hadn't ridden to work in over a week. Fortunately I had a long steep hill leading away from my condo. The Beemer was real cold blooded.
Old May 5, 2011 | 05:45 PM
The (slight) trick is to do it in 2nd but also to turn on the key at the last second and hit the starter as you jump on the seat and drop the clutch. It is worth getting it to the top of any small slope. I have jumped the hawk like 20-something times & it always sucks. Buy one of these for dirt cheap bucks and leave it on float. Bike batteries never get enuff charge inless you take long trips.
Automatic Battery Float Charger & Other Automatic Battery Chargers - Harbor Freight
Old May 5, 2011 | 08:50 PM
I got a battery tender from Amazon after my no start experience. Realizing now I could roll my bike to start every day. I live at the top of a hill, even my driveway has enough grade to start the bike.
Old May 5, 2011 | 10:06 PM
lukenukem47's Avatar
I think I know how I sent my v-regulator to an early grave.
Old Jun 30, 2011 | 06:16 AM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
you can do it from a car but if you start it dont leave the cables hooked up, just pup them on to start the bike a nd then remove them or you will fry the electronics. the car at idle will not hurt the bike but DO NOT REV THE CAR or it will damage the bike.
Old Jun 30, 2011 | 06:36 AM
Tormoz's Avatar
Tormoz is on a distinguished road
Same thing happened to me two days ago. Stopped for gas and the battery was too weak to turn it over. A guy tried to help me bump start, but I put it in first gear and that got nowhere (been so long since I've had to do that, I forgot about the good advice to be in 2nd gear). Jumped from his minivan and the bike's ok. I like the idea of running a trickle charger; I suspect my daily commute is draining the battery more than charging it.
Old Jun 30, 2011 | 09:41 AM
geekonamotorcycle's Avatar
Probably a good time to check the output on your RR.
Old Jun 30, 2011 | 11:17 AM
Tormoz's Avatar
What do you mean by "RR"?
"Regulator / rectifier." I'm slow, but figured it out....
Reason
Jul 26, 2015 03:14 PM
20_rc51_00
Aug 29, 2014 09:34 PM
koth442
May 12, 2011 10:31 AM
johnpace2
Dec 5, 2010 10:55 PM
nothing
Jul 2, 2009 04:36 AM
