Li battery tender necessary? 12mo charge loss?
Old Aug 27, 2014 | 01:35 PM
20_rc51_00's Avatar
So I'm wondering since the Li batteries are full of magic do they need as much battery tending during storage as AGM batteries? I ask because I may need to store my bike for 12 mo at a time without access to an outlet in a storage locker. If I was to disconnect the Li battery and let it sit for 12mo would there be any appreciable loss in charge?
Just trying to figure out what I can get away with in a less than ideal situation.
Thanks
Old Aug 27, 2014 | 05:10 PM
Pidge's Avatar
Can you pull the battery out and put it on a tender at another location? There must be someone who owes you a favor.
Old Aug 27, 2014 | 06:23 PM
If it's a LiFePo4 battery, then no tender is required (actually standard tenders are bad for them). Unplug it after a ride and leave it in a cool, dry place. They have ridiculous shelf life compared to lead-acid. I've never tried for a whole year, but standard documentation says that they can do it.
Old Aug 28, 2014 | 06:32 PM
insulinboy's Avatar
I have an RC race shop and we use LiPo and LiFe batteries exclusively for our cars. Though they are smaller they are still basically the same thing. I have one thats been sitting on the shelf for forever and it still has a good charge. As has been said, just leave it unplugged to be sure there is nothing draining the battery.
As a side note its also best that the battery not be "fully" charged if you are leaving it for a long period of time. Lithium batteries prefer to be stored at their nominal voltage rather than full. But this is also from a race standpoint for running electric motors and every little Mah in the battery is important. You're not going to notice what little you may lose storing it at a full charge vs nominal charge just cranking a starter to start a bike
if you do have a local friend that races electric R/C cars see if they will let you drop off the battery to put it on a storage charge for you (charges/discharges the battery to a save storage voltage to sit for long periods of time)
Old Aug 29, 2014 | 09:36 AM
RoadManiac's Avatar
European Member
aa another R/C enthousiast
check Radio Control Planes, Helicopters, Cars, Boats, FPV and Quadcopters - Hobbyking
for those A123 Lifepo4 cells there awesome for our v twins
they have enough burst amperage to turn those 2 big pistons over
anything weaker wont start it,
as for I4s you can get away with less burst amp and go for some zippy type Lifepo4s
Old Aug 29, 2014 | 07:06 PM
davidka's Avatar
Any concerns that the bike's charging system is constant current? Seems like there's a risk of overcharging, even with LiFePo.
Old Aug 29, 2014 | 08:35 PM
20_rc51_00's Avatar
THanks for the input guys. From what I have read as well, it's best to leave a battery at about 50% if storing since the natural discharge rate will be less at this amount and also the battery will not suffer ill effects from storage( supposedly the battery may not charge up to it's potential if one leaves it for storage and does so at full charge...)
Old Aug 29, 2014 | 09:34 PM
20_rc51_00's Avatar
check Radio Control Planes, Helicopters, Cars, Boats, FPV and Quadcopters - Hobbyking*
I would love such a project but I don't have enough knowledge about it. I've seen the diy posts on here about wiring these up but I'm not ready to tackle that imo. I know enough to know that there is a lot that I don't know about these batteries...
My concerns would be the detrimental effects of the bikes charging system on the balance of cells. I can't imagine the charging from the bike being any good for the pack....
Also I have read too many stories of the shorai batts crapping out prematurely. I'm assuming that being a prof made pack that there is still some hickups with the technology?
edit, rereading a bunch of the posts that discussed all my uncertainties above changed my mind, battery DIY here I come lol
Reason
Jul 26, 2015 03:14 PM
firestorm_girl
Jun 14, 2013 09:45 AM
FastRED
Jun 30, 2011 11:17 AM
johnpace2
Dec 5, 2010 10:55 PM
shaagy
Mar 1, 2010 07:28 AM
