Banjo fitting size 10mmX?
Old Aug 2, 2010 | 02:34 PM
orangezuk's Avatar
orangezuk is on a distinguished road
Someone out there know or have a set off they can spec out?
Looking for the "thickness"
Not the bolt but the fitting.
Thanx
Old Aug 2, 2010 | 02:45 PM
If I'm not too confused (It happens a lot!) I'm guessing you are referring to the dimensions of the thread, ie thread pitch? M10x1.00 or M10x1.25 ?
The VTR uses M10x1.25 on the stock banjo bolts...
Old Aug 2, 2010 | 03:05 PM
orangezuk's Avatar
fitting
Nope, not the bolt/threads ect. tweety.
looking for the specs on the fitting at the ends of the lines.
As far as I know all have a 10mm dia. opening bu I need to dubble check the thickness "flat to flat"
Old Aug 2, 2010 | 03:08 PM
Since it's hard to point on the interweb... Are we talking about the width of the banjo collar then? I'll go check... I have the stock ones... Somewhere...
Old Aug 3, 2010 | 07:20 AM
orangezuk's Avatar
*pointing on puter* the flats the copper washers seal against.
Old Aug 3, 2010 | 09:47 AM
Are you talking about the stock lines or aftermarket?
Old Aug 3, 2010 | 12:20 PM
orangezuk's Avatar
The stock spec would be nice.
heres the deal. I have the ability and certified equipment to make
U.S. DOT CERTIFIED brake and clutch lines. I am looking to order some SS fittings to make up new lines for my hawk. In that didn't want to open my brake system just to get the measurement, then wait to get the fittings and make up the lines.
Banjo fittings and their perspective bolts kind'a come as a "matched pair". The cross drilled "flow" holes in the bolt should center in the fitting. The point being that if someone uses aftermarket lines that differ from stock but are using the original bolts they may be hindering the system.
I believe the fitting is a 10mm X 10mm (hole dia. X thickness) but just tring to get confirmation
Old Aug 3, 2010 | 02:12 PM
This is the reason I asked the question. Every aftermarket fitting I have used is thinner than the stock parts and the stock banjo bolts can not be used with them. So I don't know if the stock specs will be of any use to you.
Old Aug 3, 2010 | 02:22 PM
orangezuk's Avatar
Thankyou 8541Hawk,
I guess then...Do we know if all the brake and cluch banjo sets are the 10x1.25? Then I'll just order all new fittings
Old Aug 3, 2010 | 02:30 PM
On stock parts yes...
Old Aug 3, 2010 | 02:50 PM
orangezuk's Avatar
Thanks, Tweety
orangezuk
Aug 5, 2010 08:26 PM
peterpanic
May 18, 2010 09:00 AM
spladle160
Mar 5, 2010 08:03 AM
8541Hawk
Apr 30, 2008 09:07 AM
inderocker
Feb 12, 2008 09:35 PM
