Banjo fitting size 10mmX?
Someone out there know or have a set off they can spec out?
Looking for the "thickness" Not the bolt but the fitting. Thanx |
If I'm not too confused (It happens a lot!) I'm guessing you are referring to the dimensions of the thread, ie thread pitch? M10x1.00 or M10x1.25 ?
The VTR uses M10x1.25 on the stock banjo bolts... |
fitting
Nope, not the bolt/threads ect. tweety.
looking for the specs on the fitting at the ends of the lines. As far as I know all have a 10mm dia. opening bu I need to dubble check the thickness "flat to flat" |
Since it's hard to point on the interweb... Are we talking about the width of the banjo collar then? I'll go check... I have the stock ones... Somewhere...
*pointing on puter* the flats the copper washers seal against.
Are you talking about the stock lines or aftermarket?
The stock spec would be nice.
heres the deal. I have the ability and certified equipment to make U.S. DOT CERTIFIED brake and clutch lines. I am looking to order some SS fittings to make up new lines for my hawk. In that didn't want to open my brake system just to get the measurement, then wait to get the fittings and make up the lines. Banjo fittings and their perspective bolts kind'a come as a "matched pair". The cross drilled "flow" holes in the bolt should center in the fitting. The point being that if someone uses aftermarket lines that differ from stock but are using the original bolts they may be hindering the system. I believe the fitting is a 10mm X 10mm (hole dia. X thickness) but just tring to get confirmation |
Originally Posted by orangezuk
(Post 276586)
Thankyou 8541Hawk,
I guess then...Do we know if all the brake and cluch banjo sets are the 10x1.25? Then I'll just order all new fittings |
On stock parts yes...
Thanks, Tweety
