Back brake failing... Ready to take it to the dealer... Help?
Old Mar 25, 2015 | 03:52 PM
  #31
What's that expression? Player hater?
If you are scared of bad weather stay home, but don't take cheap shots at the brave riders who do it.
James, good you got your brakes back. Not sure what all the syringes were about.
Old Mar 25, 2015 | 08:44 PM
  #32
Yeah, I'm curious as well.
Old Mar 25, 2015 | 10:50 PM
  #33
NZSpokes's Avatar
Glad you got it fixed but the sad truth is riding without a working back brake is more foolish and dangerous than you clearly realize.
If wisdom was gained, it would be to never do that again. Back brakes can save your life. They saved mine when my fronts went out at 90mph in the rain.
Some would say doing 90mph in the rain is foolish.
Old Mar 25, 2015 | 11:10 PM
  #34
Wicky's Avatar
Rather than the traditional method of bleeding using the lever, and opening and closing the bleed nipple in small increments - it's a method using a large capacity catheter syringe (+ hose) to either draw fluid down from the reservoir in 'larger gulps' (remember to keep reservoir topped up) or pumping/pushing fluid up into the system from the bleed nipple.
Lidocaine gel is optional...
Last edited by Wolverine; Mar 26, 2015 at 11:20 AM. Reason: requested removal of image
Old Mar 26, 2015 | 08:08 AM
  #35
Spokes, it was on a racetrack.
Wicky, thanks for that nauseating post. Clearly that method did not work here.
Old Mar 26, 2015 | 09:12 AM
  #36
Thank you for all the detail Wicky
Tip: For those wanting to use this method or any method that uses a vacuum to bleed the lines, put some teflon tape on the threads of the bleeder. Otherwise, air gets past the threads and you won't know when your system is completely void of air.
Old Mar 26, 2015 | 04:36 PM
  #37
thedeatons's Avatar
The syringe method show above is what I used, except my syringe fit right into the HRC style tubing (reservoir delete). I pushed the fluid down into the tube, and it came out of the bleed nipple.
It was working just fine, but apparently there wasn't enough fluid going through to overcome the high spot and clear it out. Once I removed the caliper and set it up on the passenger footpeg the air bubble was able to travel up the line and out the bleed nipple.
Magura recommends this method for bleeding hydraulic clutches, and in fact their bleeding kit comes with a syringe and fluid. I love doing it this way, no pumping at all. Very quick, as long as you don't have a high spot to overcome.
James
chickenstrip
Jan 23, 2012 10:10 PM
dave99
Oct 15, 2011 12:20 AM
Acecool
Oct 8, 2011 12:33 AM
E.Marquez
Jan 11, 2009 12:46 PM
Tweety
May 23, 2007 08:34 AM
