Failing blinkers
Old Mar 6, 2008 | 06:10 PM
chickenstrip's Avatar
chickenstrip
Failing blinkers
Hi y'all
This winter, and it's not much of a winter considering I'm in CA, my blinkers have been barely working. Sometimes they'll take close to 10 seconds to start flashing, if they flash at all. I've also had some charging issues and I thought that maybe the two were related, but the blinkers have a unacceptable delay almost all the time. Does this mean the bike needs a new turn signal relay?
Thanks for the help!
Old Mar 6, 2008 | 07:57 PM
It sounds more like the contacts on the switch are dirty.
Old Mar 6, 2008 | 08:09 PM
SBR is everywhere......
Old Mar 6, 2008 | 09:37 PM
chickenstrip
Talking Ha! Ha!
Yep, I've been tapping into this forum for some time, but mostly on occasions like this one where I've a problem that may be particular to the SH.
I took the switch apart a few weeks ago and it looked practically brand new - very clean and dry. I'm wondering if connectors, including the battery's ground is corroding because the battery has some charging issues, too. I think I'll clean up all of the connections and see what I get.
Old Mar 6, 2008 | 10:51 PM
strictly guessing... bad ground... or flasher.
Old Mar 7, 2008 | 04:50 PM
riderone's Avatar
riderone is on a distinguished road
I had the same issue, I cleaned the switch, replaced the flasher and still had delayed flash, fast flashing intermittently, ect. It was a corroded connection in the back where the signal wire connects to the main harness. It had just enough resistance to make the flasher think that a bulb was out at times.
Old Mar 7, 2008 | 06:59 PM
chickenstrip
Good tip!
Thanks, I'll make sure to check it out.
Old Mar 7, 2008 | 08:56 PM
Which is why when new I clean and coat ALL connections with dielectric grease.
Old Mar 8, 2008 | 12:00 AM
chickenstrip
Hmmmm, I've never heard of dielectric grease. You buy it at the auto parts or hardware store?
Old Mar 8, 2008 | 06:08 AM
Gregw's Avatar
I've seen it at Kragen in the gasket goo section. I've used "bulb grease" that I found in the electrical department of OSH.
Old Mar 8, 2008 | 10:55 AM
chickenstrip
Thanks!
Old Mar 8, 2008 | 12:09 PM
Also available at any Radio Shack and most home centers in the electrical dept...
Old Mar 8, 2008 | 12:32 PM
DrPepper's Avatar
there is a flasher relay i think its under your seat or around your tail check and see if its operating correctly(check voltage and ground to and from there)
Old Mar 9, 2008 | 10:37 AM
Man, that's right up there with blinker fluid!!!!!!!
Old Mar 9, 2008 | 06:51 PM
Gregw's Avatar
Stranger than fiction I tell ya'
Old Mar 30, 2008 | 02:37 PM
chickenstrip
Update: I'm still having the problem with the blinker delay. Not much of a surprise since I've done only a little to solve it. I have checked all the connections now, and it appears that everything is good. I'm tempted to dismantle the switch, but I may replace the blinker relay. It looked okay, but everything has been looking okay - I'm not sure how to check it with a multi meter - suggestion?
Thanks
Old Mar 30, 2008 | 04:49 PM
Involute's Avatar
Utardian Extraordinaire
Involute is on a distinguished road
What kind of voltage is coming off the battery when at idle? believe it or not my turn signals were my first clue to a R/R going out on my Blackbird.
Old Apr 14, 2008 | 11:21 PM
Shortlived99's Avatar
Shortlived99 is on a distinguished road
Im having the same problem. I installed a blinker regulator that replaces the flasher, its a little better but still slow to turn on the blinkers. I cleaned my connections in the rear and replaced all the wiring... Guess Ill have to check the fronts. Ill try the grease tomorrow and post.
Old Nov 19, 2008 | 06:45 PM
chickenstrip
The problem lives on
Hey y'all,
I'm still having trouble with blinker delay. When it's warm, even mild, I get instant response. But now I'm getting at least a 10 second delay. It's cold out, in the 30s, and I can't help but think there's a correlation. I've checked the charging system and it appears to be normal; the battery is good; I replaced the RR. Is it time to replace the signal relay?
Old Nov 22, 2008 | 07:26 PM
RoofCleanPhenom's Avatar
RoofCleanPhenom is an unknown quantity at this point
My hawk does it every morning. Could be the connectors I guess. If the bike is warm, and the weather isn't below 60, the signals are fine. It's only when it's cold.
Old Nov 23, 2008 | 04:15 AM
Well... the only thing that really is temperature related is the grease in the switch... Take it apart and clean it... Then re-grease with vaseline... isn't affected by temps as much...
Old Nov 23, 2008 | 06:33 AM
chickenstrip
Thanks for the tip, Tweety. I do notice that the switch is 'sluggish' (stiff, hard to move). Suggestions on switch cleaner? WD-40? Special electrical cleaner??
Thanks again.
Old Nov 23, 2008 | 07:51 AM
Not WD-40... That's counter productive... Alcohol or electric cleaner is the best...
I used a fine brush and alcohol... Just make sure to get all clean and all alcohol out before applying vaseline in generous amounts...
BTW what's with Americans and WD-40?! You guy's use it for all purposes in all places... Used correctly it's good... but there are places where it doesn't belong... electronics being one...
Old Nov 24, 2008 | 05:18 AM
chickenstrip
Yeah, that WD-40 is so amazing it's confusing ... it cleans, it lubes, it dissolves, it adheres. It's magic! Kinda like shampoo-conditioner.
Old Dec 15, 2008 | 05:14 PM
chickenstrip
We had a warm spell today so I dismantled the switch, cleaned it with contact cleaner, and greased it with dielectric grease. I'll see how it deals with the cold in the next few days.
Old Dec 15, 2008 | 05:18 PM
happytrack44's Avatar
WERA #44
Did you ever consider that your Hawk doesn't want to turn? They usually want to haul *** out to the twisties. Has yours been getting enough?
Old Dec 17, 2008 | 08:49 AM
rbrais's Avatar
Just a thought about why it may be slower when cold:
Blinker relays work like a fuse that does not blow out. When turned on, a filament heats up and (I think) breaks the connection until it cools down. As a result, the current to the bulb is stopped and the bulb turns off. Once the filament cools the connection is regained and the cycle starts over again. If not enough current is getting to the filament, it will take longer to heat up. If it is cold out, it may take even longer.
Old Dec 17, 2008 | 09:00 AM
ATLSHawk98's Avatar
ATLSHawk98
my hawk did the same thing. when the temperature drops, there is significant delay in the blinkers beginning to flash. if it gets cold enough, they sometimes won't start at all. i have LED turn signals front and rear from the previous owner. i assume they are not load matched with resistors or anything because i typically have a fast flash rate. i agree with above comment that the only thing within the system that should be temperature dependent is the grease in the switch. good luck finding the definite solution!
Old Dec 17, 2008 | 09:02 AM
chickenstrip
Well, that's what I was thinking, too. I bought a new relay but haven't put it in. I'll check out what happens with the new grease first, and then move to the relay replacement if the problem is still there.
Cheers!
Old Dec 18, 2008 | 12:08 PM
chickenstrip
Update: I took the bike out yesterday in mid 30s degree weather and though there was less of a delay than the 10 second one I experienced prior to switch overhaul, there was still a 4 or 5 second delay. I'll put in the new relay next.
