damn you kickstand from hell!!!!
Old Jul 14, 2008 | 05:54 PM
nfbzike's Avatar
nfbzike
d
nfbzike's Avatar
nfbzike
p.s. it wasnt really the kickstands fault
Old Jul 14, 2008 | 06:03 PM
clarkwebb's Avatar
clarkwebb is on a distinguished road
That sucks *** man. I dropped mine off a rear stand once. Luckily the front fairing was off, and I and the frame sliders caught it.
Old Jul 14, 2008 | 06:09 PM
Erik S.'s Avatar
I learned recently while doing the brake swap, that when you remove the front axle, then the front wheel, with it on a bike stand, it will try to fall over. The shocks are allowed to move independently. My buddy caught it.
Sorry to hear that it fell.
Old Jul 14, 2008 | 06:15 PM
Thumper's Avatar
I can one up you on that, back in 99 when i got mine i was so proud of her. i was scared someone would steal it out of our work garage so i put a wheel lock on her.
After work i was eager to ride, got on her fired her up and let the clutch out.
Next thing you know my steed is laying on the concrete floor still running and i am standing over her thinking, what the heck happened.
Well she didn't like that front wheel lock very much and when i pulled out and the lock hit the caliper that was all it took fo rme to dump he on the ground.
Busted turn signal, busted fairing, dented pipe and bent clutch lever.
Here is to your misery, been there, done that.
Old Jul 14, 2008 | 09:06 PM
In the future use a piece of 1/2 inch plywood, about 12" by 12".
I dropped my first bike 25 years ago when I stepped off without putting the sidestand down.
Old Jul 19, 2008 | 09:51 AM
I've often wondered how often a wheel or disc lock results in a drop...especially with the Harley guys leaving a bar.
But hey, I'm the one who stepped off without putting the sidestand down.
Old Jul 19, 2008 | 12:38 PM
Unclutchable's Avatar
Unclutchable is on a distinguished road
lol I should market these
I cut out an 1/4" thick 12" square piece of steel diamondplate with three 6" metal stakes welded to the bottom to anchor it in place. Works great, even on the soggy ground after the nasty rains we had here in MO this year.
Could put a D ring on it and use it as an anti-theft device too I imagine, it's heavy!
Old Jul 19, 2008 | 08:27 PM
I feel your pain... I had the old VTR parked outside my old apartment complex (as usual) with the bike cover on it. In rolls a monster monsoon storm with extremely gust winds. the cover acted like a sail and pulled the bike over on the kickstand side. Bent clutch lever, dented tank, scuffed exhaust. Shitty
Old Jul 20, 2008 | 02:21 AM
PUSHrod's Avatar
I thought the ground was going to be too soft to support the bike so I parked it on asphalt when I got to work. The sun came up and beat strongly on the earth below, including the patch of asphalt under the kickstand. Intending to run an errand at lunch I found the VTR on it's side with the foot of the kickstand six inches into the pavement. Slo-mo tip over so the damage was slight but it took three friends to extract the bike out of the surface of the parking lot.
Old Jul 21, 2008 | 12:46 AM
Manning's Avatar
Manning
Sounds just like what happened to me a few years ago. Had a cover on mine outside my condo and it turned into a sail when a wicked storm front rolled thru. When it blew over onto the right side, I got lucky because it was parked at the end of the parking pad and landed in the grass. Only damage was a front turn signal pushed in to where there was almost no stalk, and the right clip-on plugged into the dirt about an inch. I think the act of plugging into the dirt softened the impact on everything else.
insulinboy
Dec 19, 2013 12:53 AM
inderocker
Aug 21, 2013 12:33 PM
Bandit400man
May 9, 2012 03:47 PM
CruxGNZ
Jun 4, 2011 09:41 AM
uchi
Mar 21, 2010 09:21 PM
