Tapping in some swingarm sliders...whats the best location?
Old Feb 21, 2007 | 01:54 PM
iamanonymous's Avatar
iamanonymous is on a distinguished road
looking for a good general area to mount the sliders. i was thinking about roughly 1/2" in on the bottom rear corners. what do ya'll think. unfortuanely welding is out of the question currently. besides these swingarms can sell pretty cheap sometimes if it goes wrong, which i doubt. should the bolt go all the way through with a nut on the back or will halfway be ok?
Old Feb 21, 2007 | 08:15 PM
marmaladedad's Avatar
Hmm?
I had my swingarm spools welded on. It was cheap and easy to do (for the welder).
Old Feb 22, 2007 | 09:03 AM
where did you get the spools from?
Old Feb 22, 2007 | 02:17 PM
Hmm?
I ordered Pit Bull brand spool adapters and spools from Terra Powersports (www.terra-powersports.com).
Old Feb 22, 2007 | 03:55 PM
sprhawk neil's Avatar
another option would be a product chaparralmotorsports.com sells part#L213-41 they are threaded inserts made for installing swing arm buttons hope this helps but I would not drill all the way through and put a nut on the back side I'm planning on having a couple of nuts welded to mine I would put them just in front of the weld before the chain adjusters
Old Feb 23, 2007 | 09:06 AM
tophyr's Avatar
tophyr is on a distinguished road
Keep in mind that the swingarm is hollow. I'd try to make them as close as possible, if not on, the plate that holds the axle. That's likely the most laterally-strong point.
Old Feb 23, 2007 | 09:35 AM
They now make sliders that fit through the hollow rear axle. Check out ebay. Only bad thing is that you can't use these with a rear stand to remove the wheel (since you have to remove the axle - duh).
Old Feb 23, 2007 | 01:39 PM
i saw those but i think they're mostly for show/posing. since like you said, to remove the wheel=no axle and they don't stay in...
Old Feb 23, 2007 | 01:40 PM
i think you are onto something, and yes i figured it was hollow, but i wont be using them to lift the bike at all. just make it slide in a fall
Old Feb 24, 2007 | 04:21 AM
Well, if you won't use them to lift the bike then why not use the ones that go through the axle?
Hell, for that matter, I've seen entire used swingarms on ebay for $30 + shipping which is probably cheaper than any S/A sliders that you can buy. IMO, it ain't worth the trouble.
Next piece of advice: Crashing sucks! Don't do it.
Old Feb 24, 2007 | 06:35 AM
blupleous's Avatar
blupleous is on a distinguished road
just looked this part up it stated it was for use with steering dampers unless i found the wrong thing
Old Feb 24, 2007 | 06:54 AM
there is two part numbers in the catalog one says for stabilizers the other one comes in a six peice set that says for swing-arm buttons? just thought I'd put them on here I've never used them but it was just another option?
Old Feb 24, 2007 | 08:02 AM
blupleous's Avatar
uhhh duhh! sorry should have read it twice cause it does say this
"Six threaded insert kit available for other applications such as swing arm buttons"
oh yeah and thanks, i am also contemplating this type of mod
Old Feb 25, 2007 | 06:13 PM
the results are in. nice and tough. perfect fit. please dont judge my glue residue.
Old Feb 25, 2007 | 06:27 PM
Birdoprey's Avatar
so how did you end up doing it ?
had it up on a stand yet ?
Old Feb 25, 2007 | 06:33 PM
drilled using 3 different bits, finished with m8x1.25 tap.
i'd say theres more threads there than on bikes with the spool kits. got super tight with no problems. no stand yet. i mostly did it to make it slide in case of a fall as i use bottle jacks. im sure there would be no probs at all with a stand though
peterdamian2000
Aug 25, 2011 06:20 PM
j shizzy wizzy
Dec 1, 2010 04:52 PM
996er
Apr 22, 2010 02:19 PM
Scoutpilot
Sep 9, 2008 10:00 PM
The Hawk Guy
Sep 9, 2007 12:26 AM
