Swingarm Swap w/rear shock
Old Jun 10, 2008 | 09:09 AM
FL02SupaHawk996's Avatar
Fastest Color
I've got a question about mounting a new rear shock. The stock rear shock as 2 bolts through it's eyes which I think are 10mm bolts (I figure) and my new shock has 1/2 inch eyes/barrings, so my question is would it be better to go with new 1/2 bolts and drill linkage out to fit or should I use spacers to fill the gap left in the eyes of the aftermkt shock and use stock 10mm bolts?
Thanks in advance for your help,
RC
Attached Thumbnails Swingarm Swap w/rear shock-penske-rear-shock3.jpg
Old Jun 10, 2008 | 05:32 PM
Fastest Color
decided to go with steel spacers found at ACE Hardware and cut down to size, but now I've got to get bushings to stop the shock ends from sliding around on the spacers/bolts at the eyes...
Should I go with metal or rubber bushings???
Old Jun 10, 2008 | 06:58 PM
SlowHAWK's Avatar
I'd go with metal... as rubber would flex under load... which is what you want the shock to absorb, not some wimpy bushing.
J.
Old Jun 11, 2008 | 05:15 AM
Fastest Color
J.
Good point Slowhawk! Metal it is
Thanks!
RC
CruxGNZ
Mar 26, 2014 09:07 PM
eezz
Jun 13, 2012 04:51 PM
eezz
May 12, 2012 12:34 AM
SloBlue
Jun 11, 2011 09:52 PM
98ILVTR
Jul 7, 2010 10:53 AM
