Racing bobbins for the SuperHawk
Old Mar 5, 2013 | 10:16 AM
captainoi666's Avatar
captainoi666 is on a distinguished road
Racing bobbins for my Kern-Stabi paddock stand.
A piece of stainless steel 40 x 15 x 5 mm with a long nut ISO M6 welded on it, fit on the end of the swing arm.
Old Mar 5, 2013 | 09:51 PM
superbeater's Avatar
I'm not where I can look at my swing arm right now but that looks like one great solution to the problem of no swingarm spools.
Pretty clever. Thanks for sharing. I might have to try that.
Old Mar 6, 2013 | 04:25 AM
An interesting No weld solution.
Can you still get to the axle nut, and axle out the other side with it on the stand?
Old Mar 6, 2013 | 06:33 AM
very interesting, pretty cool!
Old Mar 6, 2013 | 08:19 AM
Hi,
Look at picture #5. The upper side of the swing arm is similar to the bottom side. There you can push the stainless steel plate in the opening (5 mm x 15 mm).
On the bottom side I have drilled a 10 mm deep hole with a ISO M5 thread to attach the plate with a ISO M5 screw. The hole in the steel plate is 10 mm from the outer edge and has a diameter from 6 mm for the M5 screw. You have to be careful with drilling the hole into the swing arm. Don't drill in the wrong angle!
Instead of the long nut you can use a threaded round steel and welding it in the middle of the steel plate. The steel plate has the dimensions 40 mm x 15 mm x 5 mm (please translate all dimensions in inches).
You have to break the edges and corners of the plate (hope this is the right terminology), because the opening in the swing arm is not a real square.
OMG...my english is horrendous
I look for more pictures.
Cheers Buk
Old Mar 6, 2013 | 08:28 AM
Yes, but i have to change the adapter of the paddock stand. Cut the left side of the adapter. Better to use an other adapter for the spools. A simple adapter without click is the better choice.
Buk
Old Mar 6, 2013 | 09:32 AM
CrankenFine's Avatar
Your English is better than my German
The explanation makes perfect sense.
Old Mar 6, 2013 | 12:04 PM
Well it is one way to do it.
The way I do it is just drill a hole and pop in a rivnut : Rivet nut - Wikipedia, the free encyclopedia in the box section of the swingarm......
No fuss and easy
Old Mar 6, 2013 | 12:41 PM
Yeah, I just drilled and rivenutted mine too. Maybe 10min total install time.
This is interesting, musta taken tons of thought, but I think most guys dont do welding and fabricating.
Old Mar 6, 2013 | 01:28 PM
That's called, "German Engineering"
Rollin20z
Jan 21, 2009 06:44 PM
Hotbrakes
Dec 4, 2007 09:32 AM
Waterboy
Oct 4, 2007 06:52 AM
hawkbill
Jul 26, 2007 06:41 PM
skokievtr
Apr 23, 2007 09:53 AM
