Looking for HID conversion
Old Mar 27, 2012 | 08:03 PM
  #31
taskmasta's Avatar
Pew Pew...lasers
Steve...could you ask Andrew which shrouds will definately fit in the housing? Don't want to get one that is too big.
Old Mar 28, 2012 | 12:03 PM
  #32
Stevebis1's Avatar
I think much of that will come down to personal choice. For myself I have ordered the "Iris"
Start out reviewing their tech material:
Helpful information on upgrading headlights from The Retrofit Source Inc
They indicate that trimming the shroud should be expected. Most of the shrouds don't go beyond the projector lens so I am not expecting front clearance issues.
As for the side and bottom I am expecting a little trimming with my dremmel may be required.
Go ahead and call Andrew, he doesn't bite - I bet the more interest he sees from the forum perhaps the more likely we will get these shipped with less than 10 participants.
While I did not ask if he had experience with the Superhawk headlight assembly, he did not offer that he did, so I doubt he will have first hand experience here.
Old Mar 28, 2012 | 12:22 PM
  #33
HawkRider98's Avatar
Andrew recommended the GTi-R which is what I ordered.
..."We recommend the GTi-R shrouds here for the smallest Mini D2S projectors."
Old Mar 28, 2012 | 06:43 PM
  #34
Bearshawk's Avatar
just finished ordering thanks alot guys i hope i dont have much issue getting it installed haha
Old Mar 29, 2012 | 01:04 PM
  #35
Upland111's Avatar
Ordered
First Thanks to Seattle Superhawk for sparking the interest. I just got off the phone with Andrew and completed my order on-line. I ordered the Iris lens and the 5000K color.
FYI! I am told I am #3 to put in a order. In case any of you are not aware, but are interested in purchasing one of these retrofit kits, they need 10 orders before they will ship out all at the 15% discount rate.
I am hoping we do get more interest. Think of it as an investment in safety!
Thanks again.
Old Mar 29, 2012 | 06:19 PM
  #36
Not all of us put the order in yet, but soon enough I'm sure, still counting the heads I guess... Keep coming, it is a great deal!!!
Once we all get the kit, we will keep this thread alive with all the installation technical info' as well to make it easier and support the less experience members as we always do on this Forum.
Old Mar 29, 2012 | 06:56 PM
  #37
xb9Fog's Avatar
xb9Fog is on a distinguished road
Has anyone here done this mod? If so, what was your experience splitting apart the headlight housing? Just wondering how difficult that was and if you can get it apart by heating it without breaking it. Really nice mod, I'm interested if I hear from someone that has split the housing apart without incident.
Old Mar 30, 2012 | 08:39 AM
  #38
A lot of us have done similar conversions, when I did it two years ago there was no kit's available, so I made my own...
Opening the housing is fairly easy... You need a decent heatgun that you can adjust the temperature on, and two large flathead screwdrivers with wide heads... Then you pre-heat the whole housing by popping it in the owen a couple of minutes on low heat, prefferably around 70-80C (150-175F)...
Then carefully work around the edges, one screwdriver to hold the gap, another to gently pry, and point and shoot with the heatgun to get the sticky stuff to liquify and let go, just dont boil it... There are also tabs that you need to open with a smaller screwdriver... The wider the tools for prying, the less damage... And the "warm" plastic is soft and bendy, if it's cold it cracks instead... To hot though, and it goes bubbly...
Keep the sticky stuff you take apart... I wrapped mine in a piece of clean plastic bag... Then when you assemble, re-heat it and put it back... Won't work well with too much grime in it... And like when opening, stick the parts in the oven, and gently push it back together again...
Old Mar 30, 2012 | 08:44 AM
  #39
We have several members that did just that, but not with the original reflector due to the size of the actual bulb housing, but they did need to split the headlight open for this. This mod doe's make it easier in a sense that you do use the original reflector, thus you don't need to create a new part replacing the reflector housing.
Old Mar 30, 2012 | 09:13 AM
  #40
Here's one pics aren't that pretty, but gives you idea of space.
https://www.superhawkforum.com/forum...ight-v2-23440/
And if you want to get some people riled up, stick some LED strips in while you're in there...
https://www.superhawkforum.com/forum...light-d-20861/
I have a projector on mine, but not the stock housing so can't really say how hard that one was...
Old Mar 30, 2012 | 06:54 PM
  #41
Verne's Avatar
Verne
Just ordered mine. So there is one more.
Old Mar 31, 2012 | 11:10 AM
  #42
taskmasta's Avatar
Pew Pew...lasers
ordered
Old Mar 31, 2012 | 01:28 PM
  #43
jdobeckj's Avatar
jdobeckj is on a distinguished road
give d2moto a look.. good prices and a fun selection of "crap"
Old Apr 1, 2012 | 12:53 AM
  #44
The HID kits they sell is just that... CRAP... When will some people get the idea through their heads that a HID bulb without a projector is worse than the stock lighting in about 5 different ways...
If you are happy with your crappy HID bulb, fine, enjoy... But as long as you keep recommending them to others, I will keep telling you that you are wrong... Do we understand each other?
Old Apr 1, 2012 | 06:22 AM
  #45
+1 Rest my case!!!
Old Apr 1, 2012 | 08:56 AM
  #46
Stevebis1's Avatar
I put my order in Friday - It looks like maybe there are 6 orders so far? Anyone still on the fence?
As far as the non-projector kit, I have first hand experience. You will notice in my signature I have the DDM retrofit listed. You will also notice I drive a TSX so I know what a decent projector is like.
As previously discussed, there is no comparison. The retrofit bulbs are bright but they do not produce a band of light like projectors do. They also have random reflections that will annoy and dazzle others.
There are some of us who feel that dazzling others may be good as that will increase our visibility. That is an opinion. It has been argued before and I doubt opinions will be changed. That said the projector kit WILL provide significantly more light where it needs to be.
You will see better after dark. That's why I ponied up $140. The bulb retrofits can be cheap, but if your goal is to see better, I recommend you jump on this opportunity
Old Apr 1, 2012 | 09:24 AM
  #47
I'm just going to throw a little correction your way, as the terms are often interchanged incorrectly:
HID Conversion: Ballast/Harnass and HID bulb to be put into stock housing. These are cheaper and require less work. It is sold as an upgrade.
HID Retrofit: New projector along with the conversion kit to be put into an old housing, whether it be cars, motorcycles, or whatever that has an older halogen bulb. This is the full system, and often requires cutting and even alteration of the clear housing to get the full benefits of the light.
While an HID conversion loosely fits the definition of retrofit, when talking about HID headlights, a retrofit is concerned with installation of the full technology the way it was engineered and intended to be used. Like I said, the terms are often misused in casual conversation
Old Apr 1, 2012 | 09:53 AM
  #48
Stevebis1's Avatar
Correction noted!
Now someone order - I'd like to get my retrofit kit this month so I can remove my conversion
Old Apr 1, 2012 | 10:29 AM
  #49
Aw man, just when I was embroiled in working on my truck you guys gotta go and do this that I have been wanting for a while now!
I am hoping someone can post pics or results to show the difference from stock. I have the eastern beaver setup so am dragging my feet.
Question: Is projector beam HID or are they distinct? Also what is the downside to using car projectors?
Old Apr 1, 2012 | 11:38 AM
  #50
The various projectors sourced used from cars are significantly bigger than these, with odd mounting ears since they are assymetrically mounted, and that means you need to either remove the reflector and build a frame to hold it, or if place permits, graft it to the reflector in some way... The one's I used are basically showed in there with a shoehorn...
These are "car" projectors technically... But these are specifically made to bolt to the hole in the reflector on a H4 headlight, being small enough to sit "inside" the stock reflector, meaning it's more or less a bolt on modification once you have opened the headlight up...
Old Apr 1, 2012 | 01:42 PM
  #51
Thanks tweety but you're not helping me resist much.....
Old Apr 1, 2012 | 03:23 PM
  #52
I am running the Eastern Beaver and a 100/55 bulb and have way better light than stock. I have matched mine up against a buddies HID and it is nothing close. The type/color and the amount of light available is incredible. Eastern Beaver and HID retro and I won't have to worry about upgrading the lights for a while.
Old Apr 1, 2012 | 04:52 PM
  #53
So hawkrider, you are doing hid AND eastern beaver? Do you need sunglasses at night?
Old Apr 1, 2012 | 05:52 PM
  #54
I think doing both would be an overkill, I don't think you will see a difference in this case. But it wouldn't heart if you already have the Eastern B' on
Old Apr 1, 2012 | 07:30 PM
  #55
Stevebis1's Avatar
The kit comes with a relay harness. The ballast will be wired to your battery through this. I don't see where wire sizes are noted but in theory the set up will be like the Eastern Beaver.
Probably Hawkrider98 could sell his EB and save some $$$
Old Apr 2, 2012 | 02:18 PM
  #56
My order is in as well, we have 7 orders in so far, 3 left to go!
Old Apr 2, 2012 | 04:33 PM
  #57
Just wanted to link an older thread, but a good one on the same topic, Tweety thumbs up to you, as always:
https://www.superhawkforum.com/forum...etrofit-22420/
Old Apr 3, 2012 | 11:40 AM
  #58
Any additional members jumping on the deal???
Old Apr 3, 2012 | 01:42 PM
  #59
Hmmm.. I may have a stock housing somewhere. If I find it tonight I could make one and re-sell the kit.
Old Apr 4, 2012 | 09:32 PM
  #60
So, are we having #8?
