Latest Dyno Run
Old Sep 8, 2020 | 12:22 PM
  #31
Originally Posted by ACE VenTRa
If it matters to you...I will be taking out this engine and installing my next one with hi comp pistons and a balanced assembly. After that I will have a very good, very low mileage short block with a freshened up transmission for sale.
AV
LMK bout that engine...
Old Sep 12, 2020 | 12:53 PM
  #32
ACE VenTRa's Avatar
What kind of range do you average w/ the new set up?
With the most recent jetting setup it is at 38.22 MPG, that is an increase of 2.7 ish mpg...I would say that an increase like that is the difference between pushing and coasting into the nearest gas station. Not too shabby.
AV
Old Sep 13, 2020 | 05:41 AM
  #33
AV
I'm lucky I get 35 taking it easy, of course with my very active right wrist and local super Slabs to the limited and sorry twisties that are within 1.5 hours on which I can average 90+, I achieve less than 32. I'm going to go back to the stock Khein 45 pilot and mains and see how the old boy flies.
Old Sep 15, 2020 | 05:08 AM
  #34
ACE VenTRa's Avatar
Wish me luck!
Old Sep 15, 2020 | 08:27 AM
  #35
ACE VenTRa's Avatar
And here we are...I'll explain in detail later what changes were made but the end result is that below 8k rpm I made more torque and power everywhere but I lost 2 peak hp while picking up 3 lb ft 9f torque. I can still improve jetting but it's getting close.
73 ft lbs and 105 hp! Torque monster 👹
Old Sep 15, 2020 | 04:20 PM
  #36
Nice torque number.
Old Sep 16, 2020 | 11:29 PM
  #37
RoadManiac's Avatar
European Member
Havent posted in ages, been really busy with me gsxr turbo project that bitch is finaly running right and now my focus shifts to the hawk and i just wanna post my dyno sheet, bike has remus exhaust, 48 slow jet, stock main jets, lifted tank and snorkel mod, mixture screws are about 3.75 out, i was the only bike with carbs that dyno day
Old Sep 19, 2020 | 04:54 PM
  #38
ACE VenTRa's Avatar
Dang son, looking hot.
For ***** n giggles today I decided to go all in with the DJ Kit I had and see if I could make it work. My theory was that with the FDW velocity stacks which run leaner I might be able to make a DJ kit work with a K&N and my homemade flow control kit. Seat of pants says that I'm trending in the right direction. I'll cruise around a bit more tomorrow and verify but at the very least the top end power I lost has been regained and the part throttle cruise has improved with the short springs and extra lift hole. The flow control made all the difference though,, being able to dial in jetting on the fly is second to none.
AV
Old Sep 20, 2020 | 05:38 AM
  #39
ACE VenTRa's Avatar
Yep, confirmed, that is the special sauce. It's fairly cold today, 42 degrees with 58% humidity. The only issue that I sense is that I may be running a tad rich on the pilot circuit somehow. This is the current setup:
Delwood Stacks PAIR/PCV Mod
K&N Flow Control on Main Circuit
DJ Springs Stock airbox with snorkel
3 Holes
175/180 Mains
45 Pilot
2.5 Turns
Lots of power on command, smooth steady state cruise at part throttle. Starting is a touch finicky and does not need enrichening at all, minimal popping on decel. I can't figure out how I richened up the pilot circuit though...I left that alone, scrathing head.
AV
Old Sep 20, 2020 | 03:58 PM
  #40
Confirmed by your but dyno?
RedStormJ
Nov 11, 2016 06:05 PM
triplespeed
Jul 13, 2011 08:53 AM
azhawk1
Feb 21, 2007 06:20 PM
AZZKIKER
Sep 8, 2006 03:40 PM
mikstr
Jul 11, 2005 09:44 AM
