Jetting Recommendations
Old Oct 13, 2006 | 10:06 AM
Sandigee's Avatar
Sandigee is on a distinguished road
For 2000 Superhawk -- I took a hole saw and a die grinder to remove the inside of the ends of my mufflers. If anyone has done this and successfully rejetted please help. I need settings for needle, shims under needle, main jet and pilot jet.
Old Oct 13, 2006 | 11:24 AM
Radiaoktiv's Avatar
Radiaoktiv is on a distinguished road
stage one bafflectomy?
you shouldnt need a re-jet
Old Oct 13, 2006 | 12:37 PM
Shim the needles 0.040-0.060", turn mixture screws to 2 turns out, stock mains, stock idle jets. I assume you're somewhere near sea level?
Old Oct 13, 2006 | 01:34 PM
Sandigee's Avatar
Yes, Greg -- pretty much. San Diego, but live and ride at 2,700-3,000 feet.
Old Oct 14, 2006 | 05:37 PM
Okay, well then only shim the needles a little, like half of above. 1.75-2.0 turns on the screws, whichever works better for you. Make sure you've got a good carb sync. Our bikes are sensitive to it.
GeMs
Mar 11, 2008 10:52 PM
SuperHawkins
Apr 26, 2007 10:25 AM
NOrrTH
Apr 14, 2006 02:57 PM
mks8882
Dec 3, 2005 04:12 AM
AZZKIKER
Nov 4, 2005 06:23 PM
