jd shifter
Old Nov 3, 2012 | 08:17 AM
maniac2313's Avatar
maniac2313 is on a distinguished road
jd shifter
I replaced the stock shifter with the jd shifter... what a difference it makes!! I wasnt really happy with the shifting after the rebuild I thought the factory pro shift kit would give me smooth effortless shifting... it was worth putting it in but it still felt sloppy and clunky... put the jd shifter on and perfect smooth effortless shifting just like I wanted... definatly one of the better mods i have done!!!
Old Nov 5, 2012 | 09:17 AM
JamieDaugherty's Avatar
I'm glad to hear you like it! Enjoy!
Old Nov 8, 2012 | 08:13 AM
twist's Avatar
+1 I bought one right after I got my hawk. That stock shifter is junk, too much slop for me. The JD part has a lot more adjustability and combined with hawkrider's adjustment, Shorter shifting 'Hawk the shifting has become precise and easier for me with my big flat feet.
Old Dec 19, 2012 | 09:01 PM
crappybik89's Avatar
crappybik89 is on a distinguished road
where did you get the jd shifter from?
Old Dec 20, 2012 | 06:28 AM
wolfgun's Avatar
wolfgun is on a distinguished road
Hey Maniac, make sure you either use a locking washer or some loctite on the toe portion of the shifter. It will vibrate off. nothing like trying to hit 3rd only to have the lever be gone. I found mine the first time in the driveway, tightened it down pretty damn good only to lose it the next week because I didn't pick up the clue to loctite the threads. Now I have a knurled aluminum toe piece. Otherwise, they're pretty fantastic compared to the stock shifter.
Old Dec 20, 2012 | 06:42 AM
Probably a good idea, some thread locking compound on the pivot bolt is advised as well.
That said, I've been running the first prototype on my own bike for a few years now without any thread locker - no problems. That includes a track day..... until a little fourth turn action ended the VTR's day.
Old Dec 20, 2012 | 08:30 AM
twist's Avatar
loctite=good! also take a look at "shorter shifting hawk" for adjustment that should get the full advantage of Jamie's awesome part!
Old Dec 20, 2012 | 10:17 AM
I do not suggest combining those two. Using the lower linkage mounting point will shorten the shifter throw considerably. Adding to that will create a potential for problems. Just a tip.
Old Dec 20, 2012 | 01:45 PM
So to highjack the thread a little bit...
Jamie, did you ever seriously consider making the matching brake pedal? I'm still interested, cuz I know I asked you years back the same question.
Old Dec 20, 2012 | 02:21 PM
twist's Avatar
what kind of problems you talkin' 'bout? I did it and the shifting has become much better, just a nudge, very positive. Did I miss something?
Old Dec 21, 2012 | 04:28 PM
Yep, I designed it up a couple of years ago but it was too expensive to make. Maybe I'll revisit it....
It's just too much and can cause a jam. If you are careful it can be ok, but add the extra you get with my shifter to changing the clocking at the input shaft and it could become a problem. Doing just the shifter alone should be plenty for all types of riding, IMHO.
Old Dec 21, 2012 | 04:58 PM
My bike has shifted great even since installing one of Jamies shifters.
Shawn Torpey
Feb 22, 2007 03:46 AM
ejizzle
Nov 1, 2006 06:14 PM
MXC
Jun 14, 2006 04:14 PM
DaxMiddler
Apr 29, 2006 03:25 PM
AZZKIKER
Feb 9, 2006 08:10 PM
