Which front end?
Old 08-15-2008, 07:09 PM
VTR Thunder's Avatar
VTR Thunder is on a distinguished road
Which front end?
Considering changing the frontend on my firestorm.
What are my options? Had a friend with a 954 frontend that was pretty happy with it.
Any thoughts or advice?
VTR Thunder is offline
Old 08-15-2008, 07:32 PM
superbling's Avatar
cbr's: 900,929,954,1000rr and rc51 have all been tried with success. With those you'll need the entire front end from the wheel up plus some sort of clip on solution. AFAIK, no one has posted a 600rr mod yet and I'm surprised.
I went with an F4i.
superbling is offline
Old 08-15-2008, 07:40 PM
There's lots of combos that have been done by members here. A search of the archives will help you make a quality decision. Your riding style, body size and weight, and road conditions prevalent for your area are important too. For lighter riders, working over the stock equipment is the best. And easiest. After that it's tires, tires, tires.
nuhawk is offline
Old 08-15-2008, 08:17 PM
Shredding Asphalt
MisfitToy's Avatar
I have a CBR1000 front... I love it, havent tested it with other swaps but doesnt matter im happy
MisfitToy is offline
Old 08-15-2008, 08:22 PM
SlowHAWK's Avatar
929/954 parts are pretty plentiful.... so not a bad choice...
RC51 will give you a bit more flexibility on where you set the forks in the triples as they are the longest (yet still shorter than stock VTR's.) but are probably more expensive...
I'm using basically an entire RC51 (SP1) setup with a 929 lower triple and I like it alot.
J.
SlowHAWK is offline
Old 08-15-2008, 08:23 PM
Hawkrider did the same transplant over the winter and reports are all good. He's 225/upstate NY/knows how to bring it.
nuhawk is offline
Old 08-31-2008, 03:13 PM
ReNoob
Sablotny's Avatar
Sablotny is on a distinguished road
So, would this fit?
CBR1000RR with Tokico calipers
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
Sablotny is offline
Old 08-31-2008, 03:38 PM
Gregw's Avatar
Originally Posted by Sablotny
That's what I swapped to, so yes. I have the 04-05 forks with an 06 wheel. The rotors on the 06 are bigger. I had to buy some spacers to move the calipers out, but that is a stock part. A non issue if you get the 04 wheel.
I wound up using 929/954 triples though, so I can't be 100% sure the 1000rr triples are the same. A search will turn that info up.
Gregw is offline
Old 08-31-2008, 06:01 PM
KC-10ENG's Avatar
I have the same set up as Slowhawk RC everything but 929 lower triple and I used a 929 wheel but you have to do some modifying to make the wheel work. If I did it again I would use the RC front wheel and change the back to a 900RR rear to match
Dennis
KC-10ENG is offline
Old 09-03-2008, 01:12 PM
The 1000RR triples are a few millimeters (or fractions of inches if you prefer) wider which makes it neccessary to trim the fairings, also it has some ugly mounting holes for the steering damper of the CBR1000RR (which needs a speedsignal from the CDI to work, I gave up that project...)
I'd recommend getting this os something similar as it has the wheel axle and spacers, then get a matching wheel/rim with rotors, and match it up with a set of 954/929 triples and you are set to go...
BTW: Dang it, if you got that... If so you got it cheaper than what I had to pay for mine... Altough I got a working master cylinder though...
Tweety is offline
Old 09-03-2008, 01:19 PM
And a word of advice... with those brakes... it's two fingers... Nothing more dammit... My first trialrun I did a front end wheely combined with black marks... and I nearly wet my pants... Totaly different beast than stock...
Tweety is offline
Old 09-14-2008, 04:01 PM
hardened stihl
vermontzx6r's Avatar
vermontzx6r is on a distinguished road
is it possible to install cbr 900-1000 rotors and calipers without swapping the entire front end??
vermontzx6r is offline
Old 09-14-2008, 04:22 PM
Erik S.'s Avatar
Vermont, I'll find the thread later, it's about which brakes are bolt on. Includes pistion sizes for the M/Cs and calipers.
RC, 929/954, F4i, and a list of others are nearly bolt on.
I did 929 calipers and M/C. Only had to shave a few thousandths off of the mounting ears. M/C bolted right on. Stock rotors.
Erik S. is offline
Old 09-14-2008, 05:01 PM
my e-penis is huge!!
SPRHK's Avatar
SPRHK is an unknown quantity at this point
02 GSXR1000 TOKICO 6 PISTON CALIPERS WITH STOCK VTR MC / EBC HH PADS / SS LINES IS ALL YOU NEED. HUGE DIFFERENCE OVER STOCK!!!!
This is a bolt on and go mod. no shaving /adding / shimming / twisting / bending / swearing / cussing / temper tantrums necessary!!
SPRHK is offline
Old 09-14-2008, 05:06 PM
SPRHK's Avatar
As for the forks, Racetech springs / Gold valves. Then have a repetable shop set the suspension for you. I weigh 250 lbs and it is set up and handles like a MO FO! Best money ever spent.
SPRHK is offline
Old 09-14-2008, 05:27 PM
ReNoob
Sablotny's Avatar
SPRHK - can you give me a ballpark of what the shop charged you for the springs, valves and labor? I'm going to start calling shops in the area myself.
Sablotny is offline
Old 09-14-2008, 05:33 PM
SPRHK's Avatar
For springs and Gold valves, that should run you around $250-$275 for parts. I did the install myself and only paid for final suspension set up which ran me $35.00.
If you get a guy to charge you by the hr for the job ,ballpark it should run you 250-300 bucks. The local shop out here gets 700-800 for parts and labor. I have my own PT MC repair shop, so I have an advantage.
SPRHK is offline
Old 09-14-2008, 05:45 PM
You could always talk to Hawkrider/Greg... He's set up a couple of forks for people on the forum, Nuhawk is one of them... and he seems happy with the result...
And what he charges you for the work is what I consider close to stealing...
Tweety is offline
Old 09-14-2008, 05:51 PM
Gregw's Avatar
Not for the customer though. For them, it's a great deal. (Just to clarify, it might be taken differently than what you meant )
Gregw is offline
Old 09-15-2008, 03:55 AM
Well yeah... to clarify even further, it's cheap... damned cheap...
Tweety is offline
theosagekid
12-30-2013 09:47 PM
thedeatons
11-27-2013 11:30 PM
Forde
02-28-2011 05:08 AM
uchi
08-17-2010 10:15 AM
bigbob65
05-12-2007 07:35 AM
Quick Reply: Which front end?
