clutch rod
Old Oct 28, 2011 | 10:35 AM
saige's Avatar
the boss
clutch rod
Im wondering,haven't really found a for sure answer,can the clutch rod be pulled out and put back in without ruining anything at all or having to get it in a specific spot.will it slide right back into where it properly belongs.
I have a new/used one and im thinking just maybe mine is warped a bit,so wanna take it out and see.any advice would be great.
Old Oct 28, 2011 | 11:01 AM
Yeah you can just pull it out. Look at it when you do as it does have two different ends on it, so you can make sure to put it back in the correct way.
Old Oct 28, 2011 | 11:32 AM
saige's Avatar
the boss
thanks alot,this helps alot,got the whole bike apart and trying to do as much as i can in one lump.
over heating problems,start button,clogged hoses,bad R/R,choke problems etc etc lol,its gonna be a long day.
Old Oct 28, 2011 | 11:58 AM
No worries. I think the long machined end goes in first but it has been a while since I've had mine out.
It should show it in the service manual in one of the pics.
Old Oct 28, 2011 | 12:16 PM
saige's Avatar
the boss
i was looking at the new/used one and both ends are the same,no difference.
Old Oct 28, 2011 | 12:55 PM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
it will come out and go right back in with no problems
Old Oct 28, 2011 | 04:36 PM
Are you looking at the ends themselves?
What I ment was the shaft itself should be turned down a few inches on one end.
I have a spare out in my stuff I'll try to get out there and look at it to see if maybe I'm just getting old......lol
Old Oct 28, 2011 | 04:59 PM
saige's Avatar
the boss
lol,ok,maybe they changed thru the different years
Old Oct 28, 2011 | 06:08 PM
Well it even kind of shows it on the parts drawing though it does go the opposite way then I remembered.....lol
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
See how it has the line towards the clutch slave cylinder?
Ok I just looked at my new one. One end has a black tip, that goes in first. The other end should have a long gold colored section or at least smooth looking. That end goes out as that is what rides in the seal.
So yes there are two different ends.
Old Oct 28, 2011 | 06:23 PM
saige's Avatar
the boss
i see on mine where the wear marks at.one side is shiny which shows that was the cylinder side.
thats the only indication i have of which end goes in.it should work out,im about to get to that next.
i expected to be done with everything arond 9,but you know how that goes,problem after problem.but its coming along.
Old Oct 28, 2011 | 06:48 PM
jay956's Avatar
wont oil come out or is it high enough? never done it on the hawk but i know oil would poor out of it on my old vfr.
Old Oct 28, 2011 | 06:58 PM
saige's Avatar
the boss
oil,as in clutch fluid or motor oil.
no motor oil will come out at all and the clutch fluid wont either if you leave one screw in the cylinder,it all will come out as one unit,than you could pull the rod or whatever else you need to do.
Old Oct 28, 2011 | 07:29 PM
jay956's Avatar
was referring to motor oil.
Old Oct 28, 2011 | 07:35 PM
saige's Avatar
the boss
its above anyplace that would have a oil left over.
Old Oct 28, 2011 | 08:01 PM
No oil will come out unless you start the engine....
I guess they changed things on the newer models..... well other than that I guess you really can put it in whichever way you like....
Old Oct 28, 2011 | 08:54 PM
saige's Avatar
the boss
lol,we will find out.
Old Oct 29, 2011 | 05:07 PM
saige's Avatar
the boss
we were both right,the new one i have is not anything like you said,but when i pulled mine out of the bike,it was exactly as you described,my clutch rod was still good.changing the line and cylinder did wonders tho.thanks for the help.
mikstr
Jun 11, 2026 12:30 PM
mikenap
May 7, 2015 08:37 PM
maniac2313
Jun 28, 2011 04:53 AM
Miked9
Feb 17, 2009 01:17 PM
Blkbird
Oct 12, 2008 11:27 PM
