Bafflectomy!!!!
Old Jun 6, 2009 | 08:07 PM
  #31
Gregw's Avatar
Originally Posted by merlyn
I have a problem!I ve make the bafflectomy with 4 holes each not 8 and now my bike is running hotter!What should I do_?
I wonder if your running a little lean in the jetting now. That could raise the temp.
Old Jun 7, 2009 | 05:48 AM
  #32
merlyn's Avatar
merlyn is on a distinguished road
what should I do to adjust this?
Old Jun 7, 2009 | 06:29 AM
  #33
nath981's Avatar
no disrespect intended merlyn, but you need to provide more information. Is there someone who can help you with this? drilling a couple holes is not likely going to cause "running hot" unless you drilled them in the radiators.
Old Jun 7, 2009 | 06:58 AM
  #34
merlyn's Avatar
after I ve drilled the holes I ve observed that when I run my bike in the city traffic conditions the temperature is always after the middle a bit
Old Jun 7, 2009 | 07:37 AM
  #35
nath981's Avatar
Hell, that's normal> don't worry about it if you checked all the other stuff i cited previously. grow some *****! Take the whole rear baffle out, that is, cut the whole center out. The sound is glorious and it won't hurt a dam thing. then you'll find out for sure that you're not going to overheat. If you run good synthetic oil, heat is not a problem. you can run well over 200 degrees and never hurt anything.
Old Jun 7, 2009 | 11:38 AM
  #36
merlyn's Avatar
thanks! I run motul 300 v racing line double ester 10w40
superdave
Jun 16, 2024 06:19 PM
itsjason13
Jul 31, 2006 04:04 PM
bluevtr
Jun 12, 2006 12:03 PM
mtmansl
May 26, 2006 06:20 AM
MarkCoburn
May 18, 2006 10:59 PM
