900rr swing arm brace
Old Dec 30, 2011 | 06:28 PM
zmaniv's Avatar
Hey looking for pics of the 900rr swing arm brace on the vtr Anyone got any?
Old Dec 30, 2011 | 07:06 PM
1971allchaos's Avatar
I got a lower braced (swinger) swingarm.. And I just got another 900rr swingarm that will be used to "FAB" another braced swingarm(This one will have the brace on the top) If you are still looking for pictures in a week or so to come... I should be able to post a few..
Old Dec 30, 2011 | 08:00 PM
Old Dec 31, 2011 | 03:51 PM
zmaniv's Avatar
Thanks
Old Jan 1, 2012 | 04:30 AM
Squid's Avatar
zmaniv, Sorry for thread jacking you here but 8541Hawk: If that is your swinger did the person put it in a jig when they welded it up for you and does it seem to be a common practice? Guys up here want an extra 100 just to put it in a jig and weld it up for me.
Old Jan 1, 2012 | 10:06 AM
There was no jig used on mine.
The brace was tack welded on, I then took it home and did the test fit.
After that I took it back and he finished the welds.
Old Jan 1, 2012 | 10:17 AM
zmaniv's Avatar
8541hawk do you know the al composition is it 6061 or 7075?
I plan on removing my rear wheel from my spare bike to mock up the rear brake boss and brace.
Old Jan 1, 2012 | 10:51 AM
That is something I don't know.
Old Jan 1, 2012 | 12:15 PM
2whltuner's Avatar
900rr swingarm brace
Old Jan 1, 2012 | 12:25 PM
Does the front of the brace hang into the shock area?
It might just be the pics but it does look like your brace is a bit too far forward.
Also have you run into problems not dishing out the shock cut out area?
On mine I needed to do it so the shock wouldn't hit when bottomed.
Old Jan 2, 2012 | 02:23 AM
Revelation's Avatar
Revelation is on a distinguished road
Still to be powdercoated black
Old Jan 2, 2012 | 06:14 PM
2whltuner's Avatar
yeah it appears that the front of the brace hangs out there, this picture #0397 was before the weld up, I used the installed wheel assy as my jig with everything torqed to spec,
yes I did "dish in" the front of the brace to conform with the shock cutout on the swingarm in order to clear the shock on bottom out.
Old Jan 3, 2012 | 12:09 AM
Revelation's Avatar
I also cut away a bit in the front to go around the shock.
Hopefully it will be less visible when everything is black.
Old Jan 3, 2012 | 10:40 AM
Well what I don't like on your set up is how you take the front box section, where it welds to the swingarm, and cut it so you only have the back wall left.
It is easier to mount that way but, IMHO, you lose a lot of structural integrity with that method. Unlike the box section, the single wall should be able to twist under load
I'm not a structural engineer or anything but that is why I mounted mine the way I did.
Old Jan 3, 2012 | 01:36 PM
zmaniv's Avatar
8541hawk so you also cut off the center part and flipped it?
Old Jan 3, 2012 | 01:58 PM
Matt_Hawk's Avatar
Wild Man
Man, that Aprilia subframe and tail cowl looks awesome.
how did you get to fit?
Old Jan 3, 2012 | 03:38 PM
No I didn't cut the center off. I left the box section the way it came except for the cut out needed for the shock.
If you look at the pics Revelation posted, you can see where that brace was cut so only the back wall of the box section is welded to the swingarm and then an angled plate was welded on the front to close the box section back up.
This type of mounting will allow the brace to flex, which is not a good thing IMHO.....
Here are the pics from when it was just tacked together to test for interference.
Old Jan 3, 2012 | 04:07 PM
zmaniv's Avatar
That's strange my brace looks like revelations. Looks like two squares joined by a plate and the cavity between the two faces the shock.
Old Jan 3, 2012 | 04:27 PM
That would be a later model brace than the one I used but it mounts the same way.
If you look at the first photo that Rev posted you can see what I'm talking about with the only welding the rear wall of the center section to the swingarm.
It would be like if you took your square sections, that you have, and only welded the rear wall of them to the swingarm. Then cut them at an angle to clear the shock (and so they don't just stick out into open space) and then box up the now open sections.
IMHO for the brace to function properly the whole center section, whether the two square legs or the rectangular layout, should be welded to the swingarm.
Old Apr 27, 2021 | 04:52 PM
color me gone's Avatar
color me gone is on a distinguished road
Just wanted to thank the good people on this thread. I wanted to under brace my Kawasaki arm,(looks only) and I didn’t want round tube. Did not want to spend a load of money on a custom arm.
While looking for square tube options I chanced upon this thread. Bought a $60 900rr arm and bam!!
couldnt be happier. So thanks a bunch for taking the time to post. Much appreciated.
cmg
Old Apr 28, 2021 | 04:50 AM
Thumbs up
cmg
Nice! Glad it helped.
Jack Flash
Aug 13, 2015 12:25 PM
Hangfly
Jun 5, 2015 10:11 PM
captainchaos
Jan 31, 2015 03:16 AM
thedeatons
Aug 2, 2013 04:40 PM
evil-kev
Jun 28, 2006 09:13 AM
