LED turn signal install question
Old Jun 24, 2005 | 08:50 AM
Shmittay's Avatar
Shmittay
Ok so I bought a set of Mototeck flush mount LED signals for the front, not remembering that the fronts are 3 wire But now when I look at all of the aftermarket front LED signals, I see they are all pretty much made 2 wire. So my question is, how the heck do you wire it up so that you can get both running lights and turn signals.
Old Feb 23, 2006 | 02:57 PM
Cheesedrug's Avatar
Cheesedrug
Re: LED turn signal install question
I need the same advice but no response in months..lol
Ground is green...orange is ? orange with white stripe is ?
Please help as I have the old lights off and am trying to get this done outside before dark. Thanks a ton.
Old Feb 23, 2006 | 04:05 PM
Cheesedrug's Avatar
Cheesedrug
figured it out...touch both positive wires to the running light and the one that is dimmer belongs...the other is the turn signal light. But now I do have another newb question...Are the rear turn signals supposed to be on all the time(running lights) or are they supposed to be off unless signaling. Mine are off unless signaling...Is this right??? Thanks.
Old Feb 23, 2006 | 06:13 PM
superhawk22's Avatar
Rears are blinkers only you're fine.
Old Feb 23, 2006 | 11:18 PM
swordfish's Avatar
the 3rd wire is a running light lead. some signals can be running lights, and some can't if your signals have 2 wires (pos,neg) then it can't. if 3, it can. personally, I hate running lights.
Old Feb 24, 2006 | 07:20 AM
Cheesedrug's Avatar
Cheesedrug
Thanks for the replies guys. Whew...I was a little worried that I did something that messed up the rear blinkers. I did install the running light option...but I may disconnect it later. The LP flushmounts look awesome and I am really pleased. I will post pics soon.
Stevebis1
Aug 8, 2014 08:26 AM
salmanilla2000
Oct 6, 2008 08:43 PM
handkaudio
Jul 20, 2008 07:29 AM
haknslash
Jul 16, 2008 03:51 PM
cb21983
Mar 21, 2006 05:59 PM
